Power Window Stopped Working
Old Mar 22, 2013 | 07:31 PM
LARIAT 85's Avatar
LARIAT 85
The passenger's side power window on my 1985 F150 Lariat just stopped working. It is stuck about 1/2" from seating at the top. When I push the passenger's side power window button on either side (driver's side also has a button for the passenger's side power window), nothing happens. No noise, no groan, nothing. It won't move up or down at all. The driver's side works, (although it moves very slow) so I suppose that would eliminate a fuse problem.
1. - How can I temporarily get the window all the way up until I can properly fix the problem?
2. - Where do I begin to fix this?
Old Mar 22, 2013 | 08:35 PM
ctubutis's Avatar
ctubutis
From my EVTM & Shop Manual (1981 version, your should be similar or same):
Old Mar 22, 2013 | 09:11 PM
truckertrav's Avatar
truckertrav
To do a temp fix, remove the door panel...
You can take your hand and move the window up as you are actuating the window button...Should go up fairly easilly...
Probably the plastic prongs inside the gear case(where the motor is attached to the gearing) are broken off...You can take the assembly out (when you get a little time,,not as bad as it looks.)and clean out the plastic and put small nuts in the slots around the cam...
This worked for me as a temp fix, (that was in 1997) still working...
I took my complete assembly out by drilling out the pop rivets that hold it on and then putting 1/4 by 20 half inch bolts back in the holes to hold it on..
Anyway, it worked for me..Trav..
Old Mar 22, 2013 | 10:22 PM
Black Ford XLT's Avatar
Black Ford XLT
Right trucker trav, the gears strip out over time,leaving the window helpless .Plastic replacement gear kits are available at our local auto parts store . Lariat if you suspect a power problem in which wires can break @the door(where it hinges) try running temporary power to the motor /switch,using the diagram Chris has provided .TR
Old Mar 23, 2013 | 01:01 AM
TheKirbyMan's Avatar
TheKirbyMan
Good advice, my mom's Cherokee has a messed up wire at this exact spot (where the door hinges) and we used to have to open the door to a certain spot before the windows would work. Now they work when they're closed and only act up when I open the doors, lol.
Open the door to random positions while pushing the window button and see if it starts working.
Old Mar 23, 2013 | 05:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
P/W motor contains a nylon gear that strips, 2 possible causes. (1) The gear's lubricant turns to the consistancy of tar.
(2) There are 3 round wedges that fit around the gear to retain it in position. These disintigrate, or become ovate shaped.
DOAZ-62234A24-B .. P/W Motor Nylon Gear Kit-Includes wedges and a bottle of lube / Available from any autoparts store.
Applications: 1970/90 all FoMoCo Passenger Cars / 1975/90 Econoline / 1981/90 F100/350 & Bronco / 1983/90 Ranger / 1984/90 Bronco II.
Window regulator has a stud on its end that the window roller attaches to, then fits into the glass channel. Roller breaks, window binds up or falls down to the bottom of the door.
D6AZ-5323240-A .. Window Roller / 1980/91 F100/350, Bronco & Econoline / 1976/90's myriad Passenger Cars / Available from any autoparts store.
Worst case scenario: I'm not 100% sure if the factory installed window channel that the roller fits into...is steel or plastic, but I think it's plastic. If so, it's a notorious POS, cracks apart, window binds up.
Old Mar 26, 2013 | 07:38 AM
LARIAT 85's Avatar
LARIAT 85
Thank you, gentlemen. There is a lot of information here for me to digest.
A special thanks to Ctubutis for posting an excerpt from the actual Ford shop manual. You can't get any more thorough than that!
motorcarmike
Jun 11, 2021 10:11 AM
vans
2009 - 2014 F150
Mar 20, 2015 09:23 AM
bstephen33
Jan 20, 2011 12:07 PM
Ford Fx4
2004 - 2008 F150
Mar 5, 2007 11:33 PM
