strange problems
Old Jun 29, 2010 | 11:20 PM
shortbusted's Avatar
shortbusted
strange problems
I picked up a 2000 excursion today and I'm finding some strange problems. The ac stays on when I turn the ignition off. The window switches are also staying hot with the ignition off. Bad ignition? Bad fuses?
Truck is a V10 if that makes any difference.
Old Jun 29, 2010 | 11:21 PM
jh818's Avatar
jh818
I know the window switches still works with the ignition off while the doors are still closed. Once opened, they turn off.
Don't know about your AC, though.
Old Jun 29, 2010 | 11:27 PM
shortbusted
Should the window switches stay illuminated?
Old Jun 29, 2010 | 11:43 PM
CHELLIE's Avatar
CHELLIE
you may have a bad ignition switch, there are multible switches build into the ign switch, one may be stuck, disconnect the plug that goes into the ign switch, and see if the a/c turns off.also you could have a stuck a/c relay too, unplug the a/c relay, normally its under the hood.
Old Jun 30, 2010 | 07:36 AM
shortbusted
Went out this morniung and the radio was on. Almost like the ignition is staying in accessory mode, but I don't know why hte radio would turn itself on.
Old Jun 30, 2010 | 09:17 AM
bcrewcaptain's Avatar
bcrewcaptain
The windows and radio are designed to work for 10 min after the key is turned off(or until you open a door)
Are the running board lights on? Any lights on in the dash? Any other features working?
Old Jun 30, 2010 | 10:30 AM
shortbusted
The truck can sit for hours and I can still operate the windows without turning the ignition. No other features working with the ignition off. I located the fuse for the power windows, it was very hot to the touch.
Old Jun 30, 2010 | 11:09 AM
cutloos's Avatar
cutloos
Don't know if this helps. I had something like this myself, and after reading pretty much all I could on this site I figured it out. My front windshield was leaking and was getting the computer inside wet. Every time it rained I had a dead battery from this. Could be something like this. May not be a leaky windshield but worth a look. My radio would stay on ,but not work anytime but when in park. The heater would come on and stay on. Accessories would also. Usually until everything completely dried out. Maybe this happened enough in the past that the computer has an issue.
Old Jun 30, 2010 | 02:09 PM
UrbanXX's Avatar
UrbanXX
Sometimes this will work:
Disconnect both of the battery cables for 45 minutes. Turn the headlights on for about 3 minutes, this should drian all power out of the system.
After 45 minutes reconnect the battery cables. You should have already turned the headlights off.
Maybe just maybe a relay was stuck or the computer had a glitch and it will reset itself.
This worked for me on a SHO I had. I never did find what was wrong that caused it but it fixed it.
packrat56
Sep 22, 2014 01:03 AM
legoman0234
Apr 3, 2014 07:13 AM
harbor97
Nov 10, 2013 05:19 PM
bigal6030
Jan 11, 2010 10:07 PM
normaltype
Aerostar
Aug 7, 2006 01:40 AM
