Strange ignition problem... could use some ideas??
Old Sep 21, 2014 | 12:31 PM
packrat56's Avatar
packrat56
Ok, its actually on my wifes 64 Falcon.. But I trust the knowledge base of this forums members more than any others..
1964 base model
200 ci
Alternator was installed by PO
When I shut the car off, the generator and oil pressure dash lights stay on. I am unsure what else is energized, and power will drain.
I have to quickly turn the key to start-and then back off (without starting) and the lights will go out.
I just replaced all the parts of the ignition switch today hoping it was as switch issue.
It still does the same thing..
Old Sep 21, 2014 | 01:14 PM
mechmagcn's Avatar
mechmagcn
What alternator is installed? If it is a Delco, sounds like the energizer wire is hooked to the ignition side of the switch instead of the accessory side.
Old Sep 21, 2014 | 01:41 PM
packrat56's Avatar
packrat56
Actually.. its a Motorcraft... That mean its not the same issue???
Old Sep 22, 2014 | 01:03 AM
big job's Avatar
big job
I think its still the same issue. Try a simple test while shutting off and
the warning lights are on pull the plug on the regulator and see if the
lights go out, if so just maybe the regular points are not releasing, or
like the previous reply- like a Delco its wired wrong +plus reg.exiter
wire goes to accc. side of ign sw. Buy the way most fomoco products
went alternator in 1964 (more or less) like I had a 64 galaxy with alt.
and a 64 F350 with generator, could be an early truck. If maybe yours
could have been early with a generator & and somebody changed it
with out getting into wires = we used to put a diode on the trigger wire
(the ign. one) that ended that. cheap at radio shack.
Justin73supercamper
Large Truck
Dec 20, 2016 07:22 PM
EL_JEFE32
Oct 7, 2012 08:12 PM
Good-Deal1023
Sep 7, 2010 01:57 PM
skattnig
19
Feb 14, 2010 10:37 PM
unclethumbtack
Jul 7, 2008 06:43 PM
