Ignition Wiring Problem
Old Mar 30, 2014 | 08:56 PM
legoman0234's Avatar
legoman0234
Angry Ignition Wiring Problem
When i start my truck,
it starts just fine,
but if i have the headlights on,
then turn the truck off with the ignition it stays running
until i turn the headlights off???
Please Help,
Old Mar 31, 2014 | 01:44 AM
ctubutis's Avatar
ctubutis
When you turn the key off and the engine stays running - do the wipers, radio, heater fan, etc. also remain operative? Or is all that electrical stuff inoperable (as it should be) but just the engine stays running?
Old Mar 31, 2014 | 08:32 AM
Gary Lewis's Avatar
Gary Lewis
Legoman - Welcome to FTE! And please excuse our moderator for not welcoming you himself - he was probably high on cleaning fumes.
However, you do need to answer his questions as he is implying there may be a problem in the switch or its adjustment. But if that doesn't lead anywhere slide under the dash and look at the wiring going to the headlight switch. That wiring is known to overheat and melt into surrounding wires. If it has melted to the wire going to the ignition it would do what you are experiencing.
Old Mar 31, 2014 | 11:51 AM
ctubutis's Avatar
ctubutis
High on cleaning fumes, eh? No, it was close to 1AM when I posted that...
I actually didn't do much cleaning this time, the maids are keeping up in an "OK" fashion... so I did some house maintenance stuff - re-hang a falling-down gutter, re-installed a lamppost, stuff like that.
My questions to him - does the other electrical stuff work or not - is to try and get an idea of where the problem may be... if all that stuff still works when turning the key to OFF, the problem is definitely in that switch area. But if it's just the engine staying powered, well, that opens up all kinds of possibilities (as I'm sure you can image).
Old Mar 31, 2014 | 12:12 PM
Gary Lewis's Avatar
Gary Lewis
I think you are still suffering from staying up late. I knew where you were going, and said as much. And you are right - if things are still powered when the key is off then it is probably an ignition switch problem.
Old Apr 2, 2014 | 02:58 AM
legoman0234
yes everythign electronicall works fine
radio,
heat,
dash lights
interior lights
dome light
its all working properally
but idk why the engine stays running with the headlight switch on
when i take the key out of the ignition and turn the headlights off the engine shuts off
Old Apr 2, 2014 | 02:59 AM
legoman0234
and no nothing is powered when the key is out the ony thing that stays powered is the engine
i could post a video lol
Old Apr 2, 2014 | 07:47 AM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by Gary Lewis
.......But if that doesn't lead anywhere slide under the dash and look at the wiring going to the headlight switch. That wiring is known to overheat and melt into surrounding wires. If it has melted to the wire going to the ignition it would do what you are experiencing.
Did you do what I suggested? If not I don't have any more suggestions. The headlights are powered all the time, and if that wire melts into the ignition wire it would run with the key off and headlights on.
Old Apr 3, 2014 | 12:30 AM
legoman0234
no worries i fixed it today i had a split wired (not melted) on the cluster-plug
shorting out so i cut it and soldered it and elec-taped it and now everything is working like a champ
Old Apr 3, 2014 | 07:13 AM
Gary Lewis's Avatar
Gary Lewis
I don't fully understand what was going on, but glad you got it fixed.
BradTX
35
Mar 15, 2014 10:59 PM
rolando4812
Apr 11, 2013 03:01 PM
79super460
Jan 7, 2013 04:30 PM
Ed_B
Oct 31, 2006 10:28 AM
tcb89
1978 - 1996 Big Bronco
Feb 18, 2005 12:11 PM
