i didnt even pull my headliner all the way down. i just loosened the trim around the windshield and over the doors. just a tiny bit of fishing (almost none). i have more wires above my headliner than the dash board of the space shuttle.
Not trying to be annoying and aask dumb questions...But when i pull the headliner out, will i be able to reach the wires or is therea channel the wires run into? Didnt know how much it will suck. The truck i took them off of was a 350 custom so it didnt have a liner. And you couldnt see the wires.
There's no need to even remove the headliner at all. All of these trucks have a steel ceiling and the oem wires are above the ceiling. Take off the passenger kick panel and there are a bunch of wires and plugs, there should be one 2-wire plug not used, that's for the cab lights.
After drilling all of my holes I ran a fish from the cab light hole and it ran right down the A pillar to where the plug and wires are. Can't get any easier than that.
I just pulled front trim and the A pillar trim when taking them from the turd. I pulled the headliner down just a bit in the front. I wanted to see how they were in so I could put them back. You definitely DON'T have to pull the headliner out. And after what George and Jim have said it is even easier.
Thanks George. I pulled my kick panel to look at it and decide to just go ahead and put em on. It was super easy. I left the black wire in the plug because I grounded each light to the cab and then ran my hot from the lights down to the green wire in the plug. Works like a charm and looks slightly manlier now. Can't wait to get the clears and LEDs but this will definitely suffice for now!
scroll down to where you type your post. click go advance. scroll down a little under that. click manage attachments and upload from your computer. its eaiser than i made it sound, try it
Well like an idiot i left the wiring harness in the truck. Figured it was to hard to take out. Seems like its in there pretty well. Do i make my own harness? Or should i go back and pull a harness out?
