Cab lights
Old Jun 29, 2010 | 04:16 PM
jchosler's Avatar
jchosler
Does that make you a posting guru
Old Jun 29, 2010 | 04:18 PM
chicagodragon's Avatar
chicagodragon
according to this site, not me
Old Jun 29, 2010 | 05:52 PM
redman84's Avatar
redman84
Originally Posted by Midwest Dually
I like the clear ones that light up amber.. And the factory styling is something i would keep! I found some on LMC truck site that are really nice LEDs, a little pricey, but not badly!
Those are exactly what I want. From LMC, same style as factory, clear appearing LEDs that are amber when lit! $80 though. That's why I gotta wait.
And George that LED sceme is friggin insane!!! We use LOTS of LEDs on our ambulances. I know how to program them once on the rig and functional but don't know how to get it started.
Old Jun 29, 2010 | 06:07 PM
chicagodragon
the chip was programed on a PC. i wired them up and told my cousin what i wanted them to do and he handed me a chip back. this is the first program.
YouTube - LED Clearance Lights on F-250
iam thinking about adding the turn signals, also.
Old Jun 29, 2010 | 07:49 PM
Krisx125's Avatar
Krisx125
K i pulled cab lights off an OBS in the junk yard. I just unscrewed them from the roof and yanked. Problem is i didnt get all the connectors. I was thinking of butt connecting them ,and running the wires down behind my pillar and thru the firewall. Then tie into my orange running lights. So they will come on with the first pull of the switch. And also light up when i his the remote lock. Opinions??
Old Jun 29, 2010 | 07:53 PM
redman84's Avatar
redman84
On the truck I pulled them from, they were all connected individually to a main wire inside the head liner then it was connected to a dark green wire behind the light switch so they are on with the park lights and obviously the headlamps. The main wire was run from the head liner behind the trim panel on the driver's A post into the wire bundle for the exterior lamps.
Old Jun 29, 2010 | 08:06 PM
FARM69's Avatar
FARM69
My truck didn't come with cab lights, but I've been tossing the idea around for a long time. I've been looking for a sun visor but have yet to find anything. I would'nt mind putting 10 across the top to give it some character.
Make it look like one of them ol large cars right? lol.
Old Jun 29, 2010 | 08:12 PM
chicagodragon
from the factory, with or without roof lights, there is a connector behind the passenger kick panel where you can connect to.
Old Jun 29, 2010 | 08:26 PM
chicagodragon
i want as many as possible without looking ridiculous! thought about the amber colored washer LEDs.
Old Jun 29, 2010 | 08:47 PM
Brown Falcon's Avatar
Brown Falcon
I like the clear factory style lights. Want to get the clear lenses for mine and run amber LED's.
George, those strobe effects with yours are awesome! How did you do that?
Old Jun 29, 2010 | 08:48 PM
redman84's Avatar
redman84
Even better. I know what wire to tap into behind the **** but that would be much better. Remember what it looks like and exact location off hand?
Old Jun 29, 2010 | 08:53 PM
chicagodragon
pull the kick panel and behind it is a 2 wire connector that kinda jumps out at ya. cant miss it. ill post a pic in the morning.
Old Jun 29, 2010 | 08:57 PM
  #28
chicagodragon
i added a ulta bright 5mm led to each clearence light with a seperate line for each one so they could be controlled seperatly. a PIC micro controller does all the work. my cousin did the programming. they can do whatever you imagine. it only takes him 5 min to change the program. its triggered by the horn on the keyless entry lock.
Old Jun 29, 2010 | 09:21 PM
  #29
FARM69's Avatar
FARM69
I hear ya. Eight would probably be enough, but ten sounds better. I don't think you can really have too many. I know it looks badass on the big trucks.
Old Jun 29, 2010 | 09:26 PM
  #30
Krisx125's Avatar
Krisx125
Not trying to be annoying and aask dumb questions...But when i pull the headliner out, will i be able to reach the wires or is therea channel the wires run into? Didnt know how much it will suck. The truck i took them off of was a 350 custom so it didnt have a liner. And you couldnt see the wires.
