Oil temp
Old Jul 2, 2010 | 10:21 AM
  #31
w_huisman's Avatar
w_huisman
I've basically given up on trying to get any of my nearby dealerships to do anything under warranty, as I'm replacing my oil cooler on my dime.
My warranty expires this coming December, and there's no way I'm going to bother buying the ESP.
Old Jul 22, 2010 | 07:40 PM
  #32
el boricua's Avatar
el boricua
Originally Posted by ehgeeray
The 15deg spread should trigger a wrench light after the new firmware is installed.
Could someone tell the exact flash number that have the capability to set this code???? I'm talking to my dealer about this and they have no clue about what ECM flash cold be done to identify this problem on the truck. Mine truck is 2006.
Thanks
Old Jul 22, 2010 | 08:38 PM
  #33
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Thanks
You can read up on it. Then give it to your dealer.
Try this link:
TSB 09-24-3 (http://ww2.justanswer.com/uploads/fo..._211519_A1.pdf)
Old Jul 22, 2010 | 09:54 PM
  #34
Jayybird's Avatar
Jayybird
So what is the absolute max on EOTs? What is the crossing point when you should be concerned? I read on Bismic's sheet 215 was the max, is the norm? Thanks for the input
Old Jul 22, 2010 | 10:12 PM
  #35
bpounds's Avatar
bpounds
Actually, his spreadsheets show 200-220 as normal, and 220-235 as severe service, with alarm at 235. Personally I think anything in the low end of the severe service range is okay when towing, as long as it is correlating with the ECT.
Old Jul 22, 2010 | 10:35 PM
  #36
Jayybird's Avatar
Jayybird
Yeah,
I just went back and checked:
Oil Temp (Agreed)
Normal: 200-215
Severe: 215-230
Alarm Point: 230+
Since i've had my insight (couple weeks) i haven't seen over 210 on the EOTs. However, i haven't done much towing or hard running.
Towzilla
May 26, 2014 07:25 AM
Ford are best
May 6, 2013 08:16 AM
duckymax
Nov 28, 2011 09:23 PM
farmer ford
Jan 16, 2008 05:41 PM
flybaby_3
Aug 3, 2007 05:23 AM
