Nick, I can kind of see why they don't see an issue. Your temps are not so terrible really. It looks to me like a maximum of 16° difference, and considering you were towing at the time I would say you might just be in the early stages.
I don't think the 15° is an absolute. But I don't really know.
I know that I didn't see those kind of temps until I towed up a hell of a hill here in CA. I think the logic in the new flash must take load and time into consideration, so even if you get the flash you might not exceed the parameters Ford has set. We talk about the 15° here all the time, but I have not yet seen any documention from Ford describing all the parameters required to set a CEL.
If you can manage it, you might want to hitch up your trailer and have the tech ride along with his monitor. OR, maybe you just need to speak directly with him and ask him what he considers the limits. Skip the service writer, he won't know jack. I don't know if you can do any of that, but consider it.
As I mentioned above, that DieselCare warranty is sounding better all the time.
If you can manage it, you might want to hitch up your trailer and have the tech ride along with his monitor. OR, maybe you just need to speak directly with him and as him what he considers the limits. Skip the service writer, he won't know jack. I don't know if you can do any of that, but consider it.
Not to argue but you need to keep the SA involved since he writes the ticket that justifies the repairs. I have been very fortunate in having good SA's that listen and if they don't understand what I am saying then it's a trip to talk to the tech to get it right the 1st time. Knock on wood, hope I didn't just jinx myself.
That's a good point. And you can't really skip him anyway, you have to start with him. A good one will know when he needs to get a tech involved. Point well taken.
I believe according to the TSB they check the EOT vs ECT with the truck empty (no trailer).
If you plan on keeping the truck the extended warranty might be something to look at. It is somewhere around $2,000 for 7 yr/200,000 miles, but you have to get it BEFORE your 5yr/100,000 mile warranty is up. My truck has been in the shop about 3 times under warranty and each time it cost Ford $2,000 or more.
oil temp needs to reach 250 to burn off residual water and other waste. use rotella 5w 40 every 7500 miles and don't worry about it.
Where did you get that number. The last time I took a physics class water boiled at 212 degrees and evaporates rapidly at lower temps. If the eot/ect spreads are normal then according to your theory the ect's would be in the 240 degree range.
i'm just an old engine builder with 40 years experience in both air & water cooled engines. probably don't near as much as you, who took a physics class.
Didn't ask for your history, asked where you got that number.
I think a lot of common engine knowledge does not translate directly to the 6.0.
I have no doubt that most any of todays oil can handle 250°. That's not really the issue. The issue here is whether the oil cooler is flowing coolant onward through another cooler, one which sees 1200° exhaust. The oil temps indicate that. That's what Ford says, in TSB 09-8-3. Apparently they only really became aware of this last year. So don't feel too slighted that your 40 years of engine rebuilding experience wasn't relative.
I'll leave the topic of "burning off other waste" for another time.
Thanks for jumping in Bill. Guess I got a little excited about 250 degrees to burn off water.
