Sponsored by: Real Truck
Question about transmission fluid temp.
Old Aug 2, 2007 | 05:33 PM
flybaby_3's Avatar
flybaby_3
Picked up a transmission fluid temperature gauge and finally found where to install it but am not sure about correct temps when towing. Read somewhere on here, temp should not exceed 100 degrees above ambient air temp. Where does this number come from? Ford? ??? Only reason I question it is, on my airplane the engine oil has a max temp of 240 F after going thru an oil cooler and returning to the engine. Makes sense that after the fluid goes thru both tranny coolers it should be the same temp as the engine coolant around 200F. Seem to remember back in my trade school days transmission fluid max temp was a lot higher than I'm reading here and lubes have really progressed from the Type F days.
Old Aug 2, 2007 | 06:54 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Mine stayed pretty much at 185 the whole trip (June/July - 10,450 miles) around US of A. The only time it climbed was in the BIG mountains in the west. NEVER went over 200. See sig for what I pulled.
Old Aug 3, 2007 | 05:23 AM
Casey's Avatar
Casey
No, it comes from people here. Ford's spec is 220°F continuous, 250° for less than 30 minutes. If you do get hot, idle in park or neutral until it cools. Shutting the engine off with the trans at or above the limits will cook the trans!
UNTAMND
Jan 10, 2012 04:25 PM
florida_1959
Jan 6, 2011 03:25 PM
Ultraute
All Things Towing
Mar 7, 2005 05:01 PM
missouguy
Jan 27, 2005 01:07 AM
