Oil temp
Old Nov 5, 2011 | 09:20 PM
duckymax's Avatar
duckymax
Oil temp
Could someone help me? I finally checked my oil temp and coolant temp and they are 230deg 180deg. Is it time to change oil cooler? And if so (roughly) how long does it take to change the cooler? Thank you in advance.
Old Nov 5, 2011 | 09:30 PM
BLADE35's Avatar
BLADE35
Yes time to change the oil cooler
probably take a couple days minimum for your first time
what year is the truck??
Old Nov 5, 2011 | 09:35 PM
duckymax's Avatar
duckymax
It is an 06
Old Nov 5, 2011 | 09:48 PM
BLADE35's Avatar
BLADE35
With that kinda spread being you have a square EGR cooler Im surprised the truck hasnt popped the egr cooler being an 06
I did mine this spring and spread it out over 4 days oil cooler & Full sinister egr deleate
Try parts guy ed for the stock parts you will need 215.00 for a stock oil cooler core
Old Nov 5, 2011 | 09:51 PM
BLADE35's Avatar
BLADE35
your thermistate is also alittle cool but changing that alone wont bring a 50* spread together
do you have a coolant filter on it yet
Old Nov 5, 2011 | 10:40 PM
duckymax's Avatar
duckymax
No, I don't have a coolant filter. If I was to add one would I put it inline in the heater core lines?
Old Nov 6, 2011 | 12:13 AM
BLADE35's Avatar
BLADE35
yes tye it in before the heater supply valve and then the kits you buy go to the smallest return lines to th coolant bottle
you will also want to give it a thuro flushing before you change the oil cooler core out
Old Nov 6, 2011 | 12:31 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
Yes. As blade said. Do a restore an a VC-9 flush before you change the oil cooler. An I would do a bulletproof EGR cooler while I'm there. An then add a coolant filter as soon as possible.
Old Nov 6, 2011 | 09:06 PM
duckymax's Avatar
duckymax
Thank you very much for the help guys.
Old Nov 14, 2011 | 07:16 PM
LSAtexan4x4's Avatar
LSAtexan4x4
my truck is reading about 220 oil temp and 185-190 coolant... should i be looking at a oil cooler also... my egr is gone.... and these numbers are from my sg2
Old Nov 14, 2011 | 07:37 PM
BLADE35's Avatar
BLADE35
How did you deleate the egr???????
some methods of EGR deleate still let the egr cooler heat SOAK and can rupture
But if it a Full EGR Deleate the spread is not as big of deal but still Does Apply
I had a constant 25-30* ECT VS EOT spread when I cut the cooler open it was 90% plugged
If I was you Id be for changing the oil cooler soon you dont want a oil cooler to burst what a mess
Old Nov 14, 2011 | 07:48 PM
LSAtexan4x4
i bought it with the egr delete done.... it is completely gone with just a stainless pipe directing the coolant... the y pipe is welded shut....
Old Nov 14, 2011 | 08:01 PM
BLADE35's Avatar
BLADE35
Well it cant get Heat Soak anyway since it gone
Heres my Oil cooler with a 25-30* spread
Ford Truck Enthusiasts Forums - BLADE35's Album: oil cooler - Picture
check it out^^^^^^^^^^^^^^^
Old Nov 14, 2011 | 08:21 PM
LSAtexan4x4
well imma go for a drive to get some dinner and i will post exact numbers when i return... those pics are gnarly!!!! did you go with the bpd cooler?
Old Nov 14, 2011 | 10:53 PM
LSAtexan4x4
i was at 184-186 coolant and 210-211 oil.... so 25ish....
