intermittent egr code
Old Jun 27, 2010 | 04:51 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
I get a p0401 code every once in a while, I usually pull the egr out & clean it then clear the code. I've also been watching IAT & IAT2 temps.
with a 30 to 40* diff.
So last night I get the same code & cel, no cleaning this time just reset cause the valve hasn not been gunked up.
Today I run across town & IAT is 95* IAT2 is 97*
so I do my errands & hit the freeway for some high speed runs,
now IAT is 100 & IAT2 is 140.
is there a way to test the IAT sensors or should I be looking at something
else?
recent work has been oil/egr cooler /hpop/injector
recent oil change w/mobil 1, 5-40syn.
also running b5 bio (all in the last 3500 miles)
Old Jun 27, 2010 | 06:53 PM
gb'sfx4's Avatar
gb'sfx4
bump>>>>>>>>>>>>>>>
Old Jun 27, 2010 | 06:57 PM
bpounds's Avatar
bpounds
Have you pulled IAT-2 and cleaned that? If your valve gets gunked up, that sensor is too. Something to try.
Old Jun 27, 2010 | 07:35 PM
gb'sfx4's Avatar
gb'sfx4
I'll give that a try, thanx
Old Jun 27, 2010 | 08:29 PM
8lug's Avatar
8lug
Where is the IAT and IAT2 sensor and what does it do?
Old Jun 27, 2010 | 08:43 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
And what is good to clean the IAT-2 with? And is there anything in or on the sensor that needs to be protected while cleaning, like those little holes on the EGR valve?
Old Jun 27, 2010 | 08:45 PM
m-chan68's Avatar
m-chan68
IAT #1 is built into the MAF sensor, as it pretty much has been on most Ford products beginning in and around 2003 model years.
IAT #2 is located in the intake manifold on the runner that services bank #2 cylinders.
Old Jun 27, 2010 | 08:48 PM
gb'sfx4's Avatar
gb'sfx4
IAT=INTAKE AIR TEMPERATURE
IAT is before exhaust gas recirc. & IAT2 is after
as far as I can tell
take a look in the TECH FOLDER 6.0 bible for locations
pulled IAT2 out & it looked good , no gunk at all , intake looks good too
after being hot tanked during last repair
Old Jun 27, 2010 | 09:03 PM
8lug's Avatar
8lug
Thank you M-Chan. Do these sensors need regular cleaning like the EGR
Old Jun 27, 2010 | 09:26 PM
m-chan68's Avatar
m-chan68
Only IAT #2 gets fouled up. Tune-up cleaner or carb cleaner works perfectly.
Old Jun 27, 2010 | 09:36 PM
8lug's Avatar
8lug
Thanks again. I'll check it out.
spanky350
Apr 27, 2014 04:25 PM
RKCORPS25
Oct 31, 2013 09:10 AM
SHOOTER22250
May 15, 2013 06:53 PM
Younork
Oct 15, 2011 11:52 PM
Milwaukee1979F150
Jun 1, 2011 02:04 PM
