91 E4OD in a 93 will it work
Old Jun 22, 2010 | 07:53 PM
IHdieselfan's Avatar
IHdieselfan
I know there a little different. ie speedo cable. got a chance at a '93 350 crew cab for $800. they say the tranny only works in reverse. and i've got a 91 E4OD that needs a TC. will a 93 controller work the shift soleniods in a 91 i think the connectors are the same.
Old Jun 22, 2010 | 08:04 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i think your good to go.others will confirm or not im sure.probably something you'll have to swap.
while your waiting for that info:
while you have trans out/swapping converters,i just learned form david85 (advanced in e40d knowledge) that in 95-97 ford installed a high volume pump(F5.) just thought id mentioned it to ya,as now would be a perfect time for the upgrade.
example:
FORD E4OD TRANSMISSION COMPLETE PUMP ASSEMBLY LATE F5: eBay Motors (item 180502695382 end time Jul-02-10 07:32:53 PDT)
also as part of B&M's shift kit.they send you new valves to install in the pump.so can kill two birds with one stone while your at.
thats a heck of a deal for a 93 f350 crew!
Old Jun 22, 2010 | 09:13 PM
David85's Avatar
David85
Just looked in my book and I can't find a reason it wouldn't work. There were some changes to the solenoid body in 1994 but nothing electronic that I could find across 1991-1993.
Old Jun 22, 2010 | 10:22 PM
PLC7.3's Avatar
PLC7.3
A 94+ trans has all the upgrades....... No sense going backwards. Get yours upgraded or buy a Ford rebuilt from a internet ford dealer.
Old Jun 22, 2010 | 11:46 PM
94 smokin stroker's Avatar
94 smokin stroker
so mine has the upgrades its a 94 idi turbo auto
Old Jun 23, 2010 | 12:21 AM
LCAM-01XA's Avatar
LCAM-01XA
If the connectors on both transmissions are the same then the '93 PCM will work with the '91 trans - the change in shape was made so you cannot run a solenoid pack that is incompatible with the PCM.
Wasn't it '96 when all the hardware goodies were installed in the E4OD, and not '94? Besides, I think you're missing the main point here tho, that he's trying to turn a cheap truck into a good deal with parts he already has - not really going backwards with the swap either, since he's not installing an '89 transmission.
Old Jun 23, 2010 | 10:32 AM
IHdieselfan
thanks guys for the input. lcam-01xa hit the nail on the head. trying to use parts i've already got. i'll probably get a new tc for it.
Old Jun 23, 2010 | 11:41 AM
LCAM-01XA's Avatar
LCAM-01XA
Go with a nice aftermarket converter then, factory ones are apparently fairly weak in the lockup clutch department and like to self-destruct.
Old Jun 25, 2010 | 09:12 PM
IHdieselfan
yea theres no doubt about it it will be a heavy duty tc plus adding a huge air cooler in front plus I add a spin -on oil filter in the cooler line plus a extra cap. pan with flues.
deljac
Apr 18, 2016 08:35 PM
fjazzbass
May 9, 2015 08:58 AM
fjazzbass
May 1, 2015 09:54 PM
my91stealth
Dec 15, 2010 11:07 PM
unclemyke
May 3, 2009 11:29 AM
