Off Topic
Old Jun 25, 2010 | 09:56 PM
Rick Wallace's Avatar
Rick Wallace
Off Topic
Guys,does anyone know a GOOD forum for lincoln towncars?? I found one but it aint worth poo-poo,,thanks for any help..
Old Jun 25, 2010 | 10:11 PM
WarOzz's Avatar
WarOzz
cant help ya there Rick
Old Jun 25, 2010 | 10:15 PM
Rick Wallace
Hey Ozz,havent talked at you in a while.You keeping everybody straight out there? Ive been watching oil wash up on my fishin grounds.
Old Jun 25, 2010 | 10:23 PM
WarOzz's Avatar
WarOzz
We let joe and his hammers keep the west coast straight lol
I am getting ready for a vacation here in about a week, heading up to Washington then down the Oregon Coast, it will be the first real trip for my truck towing a 24' RV
Old Jun 25, 2010 | 11:19 PM
Rick Wallace
Good! everyone needs a vacation now and again.Im getting ready to start the resurection on my truck,gotta move it under my shelter next week.I cant fish much the rest of this year anyway with this mess we have here,Speaking of Joe,I saw a thread where he spelled a whole sentence correct!! He must be doing the hooked on phonics program!!
Old Jun 25, 2010 | 11:33 PM
oreocreaming's Avatar
oreocreaming
what kinda issues you having with it? ive owned a few.
Old Jun 25, 2010 | 11:45 PM
Rick Wallace
When I turn on the A/C It wont idle,it just dies
Old Jun 25, 2010 | 11:48 PM
joe f350's Avatar
joe f350
is ur ac comp locked up when u going to fix ur idi
Old Jun 25, 2010 | 11:50 PM
oreocreaming
well that's an every car question bud. First things first. Remove the belt. Fire it up, turn on the a8. That will engauge the clutch. Try turning the pump by hand. If it is locked up then you got a problem. If the car dies with there not bein a belt you got a short somewhere in the system. What year? Electronic ignition or a points distributor?
Old Jun 25, 2010 | 11:53 PM
Rick Wallace
No,A/C works fine,just when I stop at a light it dies,A/C off stopping is no problem.IDI gets started next week,IF that tropical depression doesnt turn into a storm and come at us like it looks like it may. Man,.storms oil spills and HEAT,,,I may have to move!~!!
Old Jun 25, 2010 | 11:55 PM
Rick Wallace
Its all electronic its a 1990
Old Jun 26, 2010 | 12:00 AM
87crewdually's Avatar
87crewdually
I had a couple of vehcles do this in the past and I ended up finding a sludged up throttle body butterfly. Remove the throttle body for the best results and get some strong throttle body cleaner and clean it until it's spotless. Give it a try or atleast check it's condition and let us know.
Old Jun 26, 2010 | 12:10 AM
Rick Wallace
Is that the area where the throttle cable hooks up? I had to have the intake removed a few months ago,the thermostat housing had a stripped bolt and was leaking,the so called mech that did it left a cable off and cost me a transmission,I didnt have this problem before that.
Old Jun 26, 2010 | 12:29 AM
87crewdually
yes, if you remove the rubber intake boot and look inside you should see the butterfly. With the car NOT running, cycle the throttle by hand and see if the backside of that butterfly is crudded up with carbon.
Old Jun 26, 2010 | 12:53 AM
swooshcmk's Avatar
swooshcmk
Throttle body and IAC are the two things I'd check. IAC might be stuck closed. Do you get a higher idle when starting it up cold or is it slow idle at startup?
[edit] IAC is the Idle Air Control - it's basically a controlled vacuum leak that the ECU opens in conjunction with adding more fuel to give the net effect of slightly "stepping on the gas" and for higher idle speed when cold. [/edit]
