Re-occuring glow plug relay problem
Old Jun 21, 2010 | 12:35 AM
av226's Avatar
av226
Two years ago I had my first g.p.r go out. Ever since then I have replaced the part 2-3 times per year. Why am I having this problem over and over again?
Thanks,
Aaron
'02 F350 7.3 4x4 cc, sb
Old Jun 21, 2010 | 04:18 AM
ron's power stroke's Avatar
ron's power stroke
had the same problem a couple years ago...tested the relay and found when key turns on i have almost 14 V at the relay then slowly drops off..this first 14V shock of power to the relay is hard on them contacts...i droped in a 15V and havent had a problem since..
Stancor / White-Rodgers - 586-903 - Relays - Sensors, Switches & Relays - Allied Electronics
Old Jun 21, 2010 | 09:02 AM
Talyn's Avatar
Talyn
Stancore for the win!
Old Jun 21, 2010 | 11:33 AM
danskool's Avatar
danskool
Go Bills !
Same here. I put 3 in also.. Had enough. Got the stancor now and been done with it.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
586-902 Stancor General Purpose / Industrial Relays
Old Jun 21, 2010 | 01:15 PM
SpringerPop's Avatar
SpringerPop
Because you haven't yet discovered "The Final Solution".
However, all the guys above are trying hard to steer you in the right direction!
Pop
Old Jun 21, 2010 | 04:45 PM
av226's Avatar
av226
It looks like the consensus is the Stancor, where do I get 2 (just in case)?
Aaron
Old Jun 21, 2010 | 04:47 PM
av226's Avatar
av226
Nevermind I looked at your post and followed the link. Thanks gentlemen.
Aaron
Old Jun 21, 2010 | 05:20 PM
snakedoc's Avatar
snakedoc
here is the right up
got mine form 586-902 Stancor General Purpose / Industrial Relays
Old Jun 21, 2010 | 06:08 PM
danskool's Avatar
danskool
Go Bills !
Aaron
You won't need Two !.. Only one. That stancor will last forever.
Old Jun 21, 2010 | 06:38 PM
SpringerPop
Unless, of course, you have two trucks!
Some do!
Pop
Old Jun 21, 2010 | 11:04 PM
av226's Avatar
av226
You guys are pretty confident. The first time it went out I was deer hunting in the middle of Wyoming. Thankfully, I bought a yahama rhino right before and drove it about 25 miles to a bar in a town where 20-30 people live. The bar and it's patrons looked liked they could have been in Deliverance. Yes, I took a gun. A friend picked me up and I got home at 2:00 a.m. without a deer. That is why I want 2.
Aaron
Old Jun 21, 2010 | 11:12 PM
snakedoc's Avatar
snakedoc
you could have jumped the 2 big studs with a screwdriver for 30 sec and it would have got the gp hot.
Old Jun 21, 2010 | 11:16 PM
av226's Avatar
av226
Good to know. Do you turn the key over and then do it?
Old Jun 21, 2010 | 11:28 PM
PaysonPSD's Avatar
PaysonPSD
The hot terminal is ALWAYS hot so no need to turn the key before you short the terminals.
aaron ford
Jun 10, 2009 03:46 AM
fordboy2
Oct 25, 2007 11:14 PM
F450 Aaron
Aug 1, 2006 05:36 PM
Aaron_W
1983 - 2012 Ranger & B-Series
Jul 18, 2004 10:27 AM
Aegerter36
May 8, 2003 10:39 PM
