starter wire??
Old Jun 20, 2010 | 09:56 PM
1969furd's Avatar
1969furd
starter wire??
i need a new starter wire? not sure of the name It goes from starter sylanoid to the starter, mine got broken and i am running it spliced it now tot he sylanoid. What is the name of this called. Truck is a 79 f250 351M 4 speed granny gear
Old Jun 21, 2010 | 12:18 AM
Dirt racer's Avatar
Dirt racer
For mine I went to a welding supply store and bought 0 or 1 gauge wire with big copper ends and made a heavy duty one. I have them on most of my vehicles. Works great.
Old Jun 21, 2010 | 12:31 AM
1969furd's Avatar
1969furd
im too cheap for that, i just want to repalce with a factory part and call it good
Old Jun 21, 2010 | 01:26 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Measure the length of your old one and ask for a starter cable, just be sure it has ring terminals on both ends for mounting on studs and not ring terminal on one end and battery terminal on the other.
Piece of advice, this is one area you want to go quality, don't go cheap. While you are under the hood now would be a good time to check/clean/replace the two battery cables also.
Old Jun 21, 2010 | 03:50 AM
Kalve's Avatar
Kalve
you can get the battery mats an things like that from DC pick them up an change the battery cables an check belts & hoses an look for leaks while you are at it.
Old Jun 21, 2010 | 04:23 PM
dynamic's Avatar
dynamic
yep... measure the old cable and head to the local parts store.
ask for a starter cable.
Better yet, bring your old one and match it up.
Old Jun 21, 2010 | 06:58 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I second the welding shop... what will a puny 6 or 4 gauge wire cost? $6 or $8?
Some 1/0 and two copper lugs would run around $10 and be a huge improvement over the fishing line you would get at a parts store or Wal-Mart.
Here is a photo of 2/0 welding cable...
Josh
oneborn2fly
Nov 17, 2014 06:58 AM
1992FordF150Custom
13
Nov 6, 2013 06:54 PM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
mrogers
1978 - 1996 Big Bronco
Sep 1, 2006 04:55 PM
DC_78
May 26, 2006 03:30 AM
