starter wires
Old Nov 16, 2014 | 06:31 PM
oneborn2fly's Avatar
oneborn2fly
starter wires
I have a 1996 F150 with 200,000 miles. I had an issue with the truck not starting. I replaced the solenoid and removed the starter. I had the starter tested at Autozone and it failed. Purchased the new starter and prepared to install it when I found the wires coming out of the starter deteriorated and cracked. Where do I get replacement wires? and what should I look out for?
Old Nov 16, 2014 | 08:30 PM
88n94's Avatar
88n94
It kind of depends on what's available and how much money you want to spend or how particular you are. If you bought the cable going to the starter from the battery, which also branches over to the fender mounted solenoid, it would be well over a hundred dollars from Ford I'm sure. Maybe that can be purchased at an auto parts store, if available, a lot cheaper. If the end of that cable is good where it hooks on the starter, you may be able to just wrap some electrical tape around the cracked places.
As far as the wire running from the fender mounted solenoid to the starter, you can probably get some wire and crimp ends on it if the complete wire is not available.
Old Nov 16, 2014 | 09:05 PM
dixie460's Avatar
dixie460
Make your own. Buy the cable and terminals and whatever else, pull the old wiring out and use it as a template to make up the new wiring.
Old Nov 17, 2014 | 04:33 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Your '96 has a PMGR starter, right?
First off, remove the little spade connector from the starter and use a ring terminal nutted down directly to the trigger stud on the starter.
This has always been a problem on Fords of this era.
If your truck has the 2in1 cable you can use two separate cables or make your own.
Otherwise, I would just measure the length and purchase a quality 2Ga. cable from the aftermarket. (Carol, Pacer, Anchor)
Old Nov 17, 2014 | 05:43 AM
dixie460's Avatar
dixie460
I think Ford changed to the PMGR starters in 93. My 96 is PMGR, so I'm sure the OP's truck is too.
Old Nov 17, 2014 | 06:58 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yea, yea, I know.
I'm just saying to eliminate the "quick connect" and all the starter hassles it causes.
Gerritd1
22
Feb 6, 2012 09:13 AM
Thunderbird7480
15
Jul 20, 2011 02:37 PM
awils961
Virginia Chapter
Feb 11, 2011 05:15 AM
rupejosh
22
Oct 29, 2009 08:17 PM
cjf5150
31
Mar 17, 2006 05:47 PM
