Exhaust Back Pressure
Old Jun 15, 2010 | 01:08 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Originally Posted by Talyn
Wire the EPBV back and unplug it, see if that makes a difference.
uuhhhh?
Originally Posted by 427 fordman
The plug for the sensor is right by the turbo pedestal on the drivers side.
Nope, thats the connector for the EBPV solenoid.
Originally Posted by redman84
Well after some digression I'm still curious how to wire the EBPV back? Also, what all goes into gutting it and have yall found any negatives to doing it?
Yeap, Im agree with you.
Ill find a write up for gut the EBPV, the only negative I can see is that you cant use it as an exhaust brake, all of the others are positive things, the main IMO is decrease the EGTs.
Old Jun 15, 2010 | 02:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
I could find this links for gut the EBPV:
https://www.ford-trucks.com/forums/501405-pros-cons-of-gutting-the-ebpv.html<O</O
https://www.ford-trucks.com/forums/801647-gutting-ebpv.html<O</O
https://www.ford-trucks.com/forums/829011-deleting-ebpv.html
Also here is a pic for another option (replease it) and a better pic of the EBP TUBE in the back of the HPOP.
Old Jun 15, 2010 | 02:58 PM
427 fordman's Avatar
427 fordman
I meant for the solenoid but just wrote the wrong thing down. Thanks Roentgeep
Old Jun 15, 2010 | 03:51 PM
redone1's Avatar
redone1
So if the EBPV is wired open and no longer in use, there is no need for the EBP sensor or tube right?
Anyone know the thread size needed to cap off where the tube ties into the manifold?
Old Jun 15, 2010 | 03:58 PM
Talyn's Avatar
Talyn
There are no negatives to taking it out.
There is an actuator valve on the pedestal, follow that to the lever underneath, wire that sucker open, which is where it should be while it's off. There is a huge spring in there to keep it open, but it fails from what I can tell.
Just use some wire and wire it open. If you need to look at what your doing, take the DP off and look right in the end of the exhaust on the turbo. You'll see a huge butterfly valve on a 1/2 inch rod. Its a huge exhaust restriction if you ask me.
Make sure you unplug it on the other side of the turbo also.
Old Jun 15, 2010 | 04:05 PM
Talyn's Avatar
Talyn
I still don't see it as an effective exhaust brake.
If you read up on this, it can only be used in certain situations and certain RPM bands.
just my opinion on it.
Old Jun 15, 2010 | 05:07 PM
Talyn's Avatar
Talyn
You need that. it has an effect on fueling.
it measures exhaust back pressure. has nothing to do with the operation of the valve.
That is determined by the AIS which is on the intake filter, and a few other things.
Old Jun 15, 2010 | 05:15 PM
redone1's Avatar
redone1
Thanks for clearing that up for me Talyn.
Old Jun 15, 2010 | 05:43 PM
redone1's Avatar
redone1
Who has the cheapest price on this egr tube? Part No. F7TZ-9D477-AA.
Rock Auto has them listed for $16-17, but it's part number F7TZ-9D477-A.
Old Jun 15, 2010 | 06:59 PM
redman84's Avatar
redman84
Aso here is a pic for another option (replease it) and a better pic of the EBP TUBE in the back of the HPOP.
Thanks man! That helps me out and I'm sure some of the others.
Now that I think of it, I have an extra on my other truck if you want it. Although I cannot guarantee it is clear and after shipping and all it is probably easier to go get one. But if you like...
Old Jun 15, 2010 | 07:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Be careful with the sensor, that puppy is slightly over 100 dollars.
Mine was accidently broken while installing a 3" down pipe and 4" exhaust.
The codes it set while broken did affect, not in a good way, how the truck ran till I got a replacement.
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
William,
I use it as an effective exhaust brake, and Im very happy with it, as many others, for instance IIRC, Neal.
William,
What does AIS stand for? I didnt find in my acronyms and definitions list, maybe you mean: IAT: Intake Air Temperature.
Old Jun 15, 2010 | 07:04 PM
  #28
Hussler's Avatar
Hussler
Talyn, are you sure on that?
The only thing the EBPV sensor does along with AIT sensor is help the PCM determine duty cycle of the EBPV. It has everything to do with the operation of the valve.
Old Jun 15, 2010 | 07:12 PM
  #29
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Do you know if the # part of the tube from RockAuto is to connect with the sensor behind the HPOP. Yours is in front or in the back?
Old Jun 15, 2010 | 07:24 PM
  #30
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
No problem, You are welcome.
