Deleting EBPV
Old Mar 7, 2009 | 12:14 PM
wmiller's Avatar
wmiller
Deleting EBPV
whaat all is involved in deleting the ebpv. Getting ready to put on a D66 and want to do away with it. can i just unhook the linkage pull the butterfly out and weld the hole up?
Old Mar 7, 2009 | 12:26 PM
tjbeggs's Avatar
tjbeggs
Yes you can do that but I prefer to get rid of the actuator as well. Removing it get rid of any oil leak potenial from the rod and it also makes it easy to to get to that one back bolt on the pedestal.
Cut the barrel off the pedestal and weld up the left over holes. Its alumnim so you will need to find a welder that can do that for you if you don't have welder needed. The pedestal will look like this when done
Old Mar 8, 2009 | 12:38 PM
wmiller's Avatar
wmiller
Thanks TJ. I got the butterfly apart and nust need to weld the holes shut. I dont have the ability to weld aluminum so i guess ill have to go to the welding shop
Old Mar 8, 2009 | 04:21 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
does gutting the ebpv give em any more oomph
Old Mar 8, 2009 | 04:27 PM
BlueMule's Avatar
BlueMule
It lets it flow better by eliminating the restriction caused by the butterfly and shaft.
Old Mar 9, 2009 | 09:06 PM
wmiller's Avatar
wmiller
Can i just remove teh guts from the acuator and tap the hole for teh shaft and plug the hole? or is there too much pressure for teh cover on the other end? I dont have access to a welder that can do aluminum and the local welding guy will charge as much or more than what i can buy from that rons turbo on ebay
Old Mar 10, 2009 | 02:12 PM
wmiller's Avatar
wmiller
bump bump. Will there be too much pressure for that back plate with the guts removed?
Old Mar 10, 2009 | 04:41 PM
Gobstopper909's Avatar
Gobstopper909
wmiller, that plate is pretty thick, i wouldnt worry.. are you suuuure you dont wanna delete the actuator? i wanted all the room i could get if any turbo problems arise. in addition to tims pic, heres what i did https://www.ford-trucks.com/forums/8...-write-up.html
Old Mar 10, 2009 | 05:09 PM
jimwilsonmasonry
if you gut the ebpv should you also get rid of the actuator ,does it leak when you gut it-does the actuator ever give anybody problems
Old Mar 10, 2009 | 06:24 PM
wmiller's Avatar
wmiller
Im just trying to save some money. Ive alreadywent way over budget rebuilding motor and upgrading
Old Mar 10, 2009 | 06:30 PM
tjbeggs's Avatar
tjbeggs
You will be fine plugging the holes. Many have done it that way.
Old Mar 10, 2009 | 08:22 PM
wmiller's Avatar
wmiller
Ok. Thats what I was looking for. Would rather cut it put since I have to pay to have it done and money is tight I'll risk causing it down the road if i ever have to pull the turbo
Old Mar 10, 2009 | 09:03 PM
aaron ford's Avatar
aaron ford
I just had to do this job. I pulled the turbo and removed the plug on the back of the actuator. I pulled the piston and cut the actuator shaft to 1/2 inch. I then tapped and plugged the actuator hole with a pipe plug.
I reinstalled the piston and the spring. I then ground the rivets out of the exhaust valve and pulled the plate and shaft. I tried to tap threads but I did not have a tap bigger than 1/2-13. I ended up using a 1/2 inch bolt inserted from the inside. I loc-tited a nut on the outside. The brass bushing sealed the bolt and nut perfectly. I would have liked to eliminated the actuator housing as suggested earlier, but for some reason decided not to... TJ Beggs even offered to do the work... I thought I would be able to use it as a brake, but the seal failed shortly thereafter. So I had to pull the turbo, again.
Aaron
JJD
Aug 1, 2016 11:01 AM
BLK01SD
Jul 4, 2016 02:12 PM
compaddict
30
May 25, 2015 02:53 PM
powerstroked162
Jan 29, 2009 11:56 AM
bigtorque
Dec 26, 2006 02:16 AM
