Do you know if the # part of the tube from RockAuto is to connect with the sensor behind the HPOP. Yours is in front or in the back?
Mines in front of the HPOP. I believe the one RockAuto has is for connecting to the back. Rockauto has DORMAN Part # 598104 which is F7TZ-9D477-A according to them.
Now that I think of it, I have an extra on my other truck if you want it. Although I cannot guarantee it is clear and after shipping and all it is probably easier to go get one. But if you like...
Does it connect to the front or back of the HPOP? I may be interested if I'm gonna have to buy a 30-50 dollar tube. If I can find one for say under 20, i'll probably buy new. Thanks for the offfer.
Either way I definately need a new one as mines junk...
No worries anymore redman. I picked one up today and put it on.
Kind of ashamed to say that I think mine has been broken for a while. I definately have more power than before.
Where did you get one?, do you have the # part and price? I want to put in my book the correct #part for the tube that goes in the back of the HPOP.
thanks.
thanks.
I got it from a buddy of mine who had a new one from ford in his garage.
Anyone figure out the right part numbers yet?? I took mine off the top and it was almost plugged so I took it off the bottom and the threads on the fitting and female end on the tube are shot. Need parts asap, can't be down long. I asked partsguyed just a little bit ago but need an answer asap.
Also what is the proper name for this damn tube anyway??
I would really like to know if it could be plugged too. I have no idea but you guys are talking about it a bit so...........
George, it goes from the pass. side exhaust manifold, right in front, and curves up to the sensor on the pass side on top of the hpop resevoir and hooks up. It's like 14-16 inches long with some bends. If you look up from under the truck on the pass side right in front of the crossmember you should see the fitting and line sticking out of the manifold.
Part# I got from Ed was F4TZ9D477A. Mine is behind the hpop
