Exhaust Back Pressure
Old Jun 22, 2010 | 03:02 PM
  #46
chicagodragon's Avatar
chicagodragon
ill go back out and check in a few. this was all i saw under the hood.
Old Jun 22, 2010 | 03:09 PM
  #47
redone1's Avatar
redone1
George look in front of the HPOP and see if you see anything. My sensor is between the HPOP and the fan.
Old Jun 22, 2010 | 03:18 PM
  #48
427 fordman's Avatar
427 fordman
Look underneath too, where I said, should see it for sure there too.
Old Jun 22, 2010 | 03:19 PM
  #49
chicagodragon
thats exactly where mine is. right above the water pump leak
Old Jun 22, 2010 | 04:49 PM
  #50
chicagodragon
if this line is plugged up, it can cause poor running issues?
Old Jun 22, 2010 | 06:04 PM
  #51
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
You should be read the posts # 13 and #14 of this thread.
Old Jun 22, 2010 | 06:18 PM
  #52
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Originally Posted by redone1
Mines in front of the HPOP. I believe the one RockAuto has is for connecting to the back. Rockauto has DORMAN Part # 598104 which is F7TZ-9D477-A according to them.
Originally Posted by 427 fordman
Forget it, Ed answered me and I ordered it.
George, it goes from the pass. side exhaust manifold, right in front, and curves up to the sensor on the pass side on top of the hpop resevoir and hooks up. It's like 14-16 inches long with some bends. If you look up from under the truck on the pass side right in front of the crossmember you should see the fitting and line sticking out of the manifold.
Part# I got from Ed was F4TZ9D477A. Mine is behind the hpop
Acoording with the numbers in this thread (including the bag of the pics from Neal: F7TZ-9D477-AA in front of the HPOP), it seems that the rigth numbers and the name of the tube are:
Exhaust Back Pressure Tube<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
(Ford) F7TZ-9D477-A (94.96 ; earlier models, behind of the reservoir)<o></o>
(Ford) F7TZ-9D477-AA (97-up; later in front of reservoir) but in some cases in this years may mount like earlier models.
Old Jun 22, 2010 | 06:29 PM
  #53
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
BTW the # part for the sensors also are different:
Exhaust Back Pressure Sensor
(Ford) F4TZ-9J460-A (94-96; mounts on bracket above oil reservoir) NOTE: Part Number F4TZ9J460A was Superseded with 1C3Z9J460AA
(Ford) F7TZ-9J640-AA (97-up; later in front of reservoir) may mount like earlier models (I dont know if this one, also was superseded for other number)
Old Jun 22, 2010 | 06:50 PM
  #54
427 fordman
Ed emailed me back and said he was getting me the updated part number one not taking any chances so maybe that is what you have there. I trust Ed, hasn't failed me yet.
Old Jun 22, 2010 | 07:01 PM
  #55
427 fordman
When I type up the first part number for the tubes you gave me in eds site it doesn't show anything. The second one does. I think that first one is wrong and is what I ordered.
Old Jun 22, 2010 | 07:18 PM
  #56
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Ok, please, when you get the answer, post here.
I also put the numbers in Powerstrokeshop and doesn´t show anything. Maybe they have been superseded
Old Jun 22, 2010 | 07:43 PM
  #57
427 fordman
I will definitely let you know when I get my part. Should be this week yet, ordered it to be here fast.
Old Jun 23, 2010 | 10:00 AM
  #58
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
the tube ordered per vin production date before 5/12/97
F4TZ9D477A
connector
F65Z9F485AA this is the new number.
no sensor was ordered.
but it would be
4C3Z9J460A
and if you want the brkt the sensor mounts too that holds the tube before 5/15/97
F4TZ9J432B
Old Jun 23, 2010 | 10:45 AM
  #59
427 fordman
There we go, Ed took care of it for me. Thanks Ed.
Old Jun 23, 2010 | 11:09 AM
  #60
Parts Guy Wyatt
Former Vendor
you are welcome.
