Hitch for a highboy
Old Jun 14, 2010 | 04:15 PM
ChaseTruck754's Avatar
ChaseTruck754
I forgot you rednecks run your trucks WAAAAY too high over there. But yes, that is how I will be doing the hitch on Muttly (the crew cab).
If you thing it's way too high then do something like this...
l[ ]l
l======l
Meaning - the "l"s are a vertical plate (I couldn't get them to stack perfectly on the right side) that bolts to the outside of the frame. The "["s are the frame rails on either side and the "="s are the tube across.
The receiver is then below the frame. If you are worried about strength - tie diagonals from the center, just above the hitch receiver to the inside of each frame rail. It can still be bolt on...
*edit* d'oh - the board program removed the space between my "frame rails" - the top line of my drawing should be spaced out as far as the bottom line.
Old Jun 14, 2010 | 04:30 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
my tires are only 2" higher than yours. When i had factory highboy springs in this it actually sat higher in the rear.
Old Jun 14, 2010 | 04:35 PM
ChaseTruck754
Then how is the hitch too high? My crewcab will be fine with my drop hitch...
Old Jun 14, 2010 | 04:37 PM
crazyredneckanyhow
I guess with the weight of the bed and a tank of fuel it might be ok. Not real confident of butt welding plates to the tube for the hitch if i put it inside the rails.
Old Jun 14, 2010 | 04:39 PM
ChaseTruck754
Then have a pro weld it
Old Jun 14, 2010 | 04:42 PM
crazyredneckanyhow
Its not that i cant. Ive had alot of people tell me my welds are fine. I guess its just the thought in the back of my mind of what would happen if something breaks loose.
You know the flaming bus full of nuns and preschools theory.
HoustonDave
17
Feb 9, 2017 10:39 AM
bigcrunch
Mar 30, 2015 10:30 PM
Mike2theMax
20
Sep 23, 2014 10:10 PM
SuperDuty93
Mar 4, 2014 09:51 AM
stydel311
Dec 20, 2013 11:52 AM
