6.0 tranny cooler
Old Jun 10, 2010 | 10:36 AM
cps's Avatar
cps
6.0 tranny cooler
For those of you that have done this swap what needs to be removed on the front end to get the stock one out and the new one in ? Does it just bolt right in place of the stocker? Do you just need different fittings and hose? What kind of temp drop did you see after the install? Thanks in advance for the help.Roy.
Old Jun 10, 2010 | 03:35 PM
sideshow's Avatar
sideshow
I removed the rubber/plastic flap up top at the hood latch. disconnected the hood latch, and removed the bolts holding the radiator in place. I didn't actually REMOVE anything but the stock cooler, it took some finesse, but it came out and the new 31 row cooler went in without mucking up any fins on either cooler. I'm sure somebody will chime in and give better directions, but that's how i did it. Otherwise, it bolts right in using the same bolts as the stocker. I did have to fab up some fittings just like Joe (Izzy351) did. search the forums for some pics. I saw a good 50-60 degree drop.
ETA: thread with pics Joe took when doing his https://www.ford-trucks.com/forums/9...ns-cooler.html
Old Jun 11, 2010 | 09:09 AM
'00RedSD's Avatar
'00RedSD
I just changed mine and I followed these steps. It was easy.
This How to Install You're 6.0 Trans Cooler -My Detailed Write-UP - Powerstroke Nation
Old Jun 11, 2010 | 11:19 AM
schlepprock250's Avatar
schlepprock250
I removed the rubber flap,removed the hood latch,loosened the A/C condenser so it would give a little,then pulled the stocker out,it took a little very careful wiggling(you don't want to damage the radiator,or the A/C condenser).I bolted mine back in the same location as the stocker,but I wondered if raising the 6.0 cooler up some(to get it "more" into the fan air path)if it would cool a little better,but after looking at it,it's in the fan air travel anyway,way more than the stocker.
Old Jun 11, 2010 | 11:30 AM
beanhead6D5's Avatar
beanhead6D5
Heres what I did with mine.
Ford Truck Enthusiasts Forums - beanhead6D5's Album: 6.0 IC mod!
Just click on the pics and read through.
https://www.ford-trucks.com/forums/8...r-install.html
This the write up I did also.
Old Jun 11, 2010 | 12:45 PM
bobbyrjw's Avatar
bobbyrjw
Not knowing any better, I went in from the bottom. I have a 4x4, so I have ground clearance room. It worked fine after I pulled off the rubber flap covering the bottom.
I got my parts at Home Depot (brass fittings) and NAPA (hose and clamps).
Old Jun 11, 2010 | 12:47 PM
bobbyrjw's Avatar
bobbyrjw
(I forgot to add) I installed a 31Row cooler. Pulling my 10K # 5th wheel went from high 190's (before) to not over 160 (after).
Old Jun 11, 2010 | 03:14 PM
beanhead6D5
Sorry about the mix up! I need to read the fine print TC not IC.
Old Jun 11, 2010 | 06:16 PM
Duzitall's Avatar
Duzitall
Holy Moly, just opened the box with my new 6.0l 26 row. wow, it's BIG
Old Jun 11, 2010 | 09:48 PM
schlepprock250
Here's the difference between the 26 row 6.0 cooler and the stock 7.3 cooler...
Old Jun 12, 2010 | 05:52 AM
bobbyrjw's Avatar
bobbyrjw
And my 31 row was 6 tubes bigger.
tonyt22
May 8, 2014 08:43 AM
mustang81
20
Jan 15, 2013 04:10 PM
2010Iron883
Feb 17, 2012 05:28 PM
spurredon
Oil & Lubrication
28
Aug 10, 2004 01:13 PM
F0rdF0rever
39
Nov 8, 2003 01:23 PM
