Retractable Running Board problem
Old Oct 7, 2018 | 07:10 PM
  #91
vipersinu2's Avatar
vipersinu2
I posted the repair pics on 9/21/10, today is 10/7/18
It has been a little over 8 years since I serviced these boards.I am having issues again. Time to do it all over again.
this time I think I will find a way to drill and tap a Zerk fitting in hinge so it can be greased.
I have a feeling this time I will need to replace the brushes.
Old Jan 3, 2019 | 03:40 PM
  #92
Jermaine Jai Smith's Avatar
Jermaine Jai Smith
2010 Platinum
Originally Posted by owenford
You need to rotate the motor housing. It contains magnets and the polarity of the magnets in relation to the motor affect the direction of the motor. So, undo the 3 screws, rotate the housing (I had to rotate mine past the next set of holes and stop at the following holes), re-attach, and re-test.
Has anyone figured out how to remove the motor. I’ve removed the board, and I’m stuck trying to get this motor off.
Old Oct 14, 2019 | 04:11 PM
  #93
nt21's Avatar
nt21
aluminum wedge
my wedge broke when i pooped it out of the bracket. does anyone have an extra one or know where I can get one?
Neil 516-641-3326
Old Oct 14, 2019 | 04:15 PM
  #94
Damit's Avatar
Damit
Just the threads stripped drill and heli coil or re thread to next size
Old Oct 14, 2019 | 04:36 PM
  #95
nt21's Avatar
nt21
Wedge
The wedge broke in half and ive been looking online to buy an new one and came across pictiure i posted. Anybody know where i can get another wedge?
Old Oct 14, 2019 | 05:06 PM
  #96
Damit's Avatar
Damit
Sorry can the wedge be welded
Old Oct 14, 2019 | 07:40 PM
  #97
racerock's Avatar
racerock
Talking
Neil 516-641-3326
Did it hurt?
Old Oct 19, 2019 | 02:53 PM
  #98
alloro's Avatar
alloro
No but if you can't find one you can make one, or go to a local machine shop and have them make one. It's looks rather simple.
Old Oct 29, 2020 | 02:09 AM
  #99
gary severson's Avatar
gary severson
Hinges
Originally Posted by fordboy300
my running boards on my 2007 Ford Explorer stopped working. i have sprayed lubricant on the hinges and it would work when they want to. Dealership told me hinges are corrosion. any suggestions on fixing hinges?
If you are sure it's just corrosion on the hinges, take it apart and take a grinder and wire wheel to it, paint it and put it back on, put some anti sling lubricant on the hinges, like chain lube. Theirs only 10 to 12 bolts don't remember for sure. No sense remembering it, because nothing the same ever breaks around here. Good luck.
Old Apr 11, 2023 | 06:53 PM
  #100
oceanbreeze67's Avatar
oceanbreeze67
1st Gear
wedge reinstall
Anyone have a trick to getting this wedge back where it's supposed to go?
dpayne7571
Aug 13, 2018 12:48 PM
Wannaspeed
Sep 24, 2017 01:11 AM
twozzie
1983 - 2012 Ranger & B-Series
Jan 19, 2017 06:05 PM
salazar44
Jan 2, 2017 03:17 PM
Fastback460
16
Feb 28, 2016 02:01 PM
