brakes locking up
brakes locking up
I have a 2000 f250 4x4 with 4 wheel abs. The front passenger side caliper keeps locking up while I'm driving and won't release and when I hit the brakes it pulls hard to the drivers side. I have put two calipers on the passengers side and put new brake lines on. Just trying to see if anyone can help.
on
Okay Stew - that puts a slightly different light on it then...
Have you checked out the front end of the truck for play in the balljoints and tie rods?
The caliper mounts - if they are slide mounts, you may have some corrosion/rust/wear on the slides which will cause a caliper to hang up and the brake pressure will then be applied un-evenly..
What did the old pads tell you? Are they worn evenly across the face?
on
The real bad thing is that if the pads have already started a bad wear pattern, there is no economical way to reverse that - you just have to replace them.
Servicing the slides -
Have to remove the calipers, clean the slides thoroughly and use a fine file to remove any rough spots. I use silicone grease to lube the slides. Yes, the grease can attract and hold dirt, but I've not found that to be a problem in normal highway use.
Did you replace both flex hoses on the front?
