brakes
Old Jan 1, 2009 | 04:24 PM
nmh2285's Avatar
nmh2285
brakes
well i just wanted to know i have a 99 ford ranger 4x4 wheel drive and i just replace the calibers the brake pads the brake shoes and the rotors r all good but something is still not right the problem occured over the last week but the abs light has been on for about 2 months i did not have time to drop it off with work and stuff the problem is when i hit the brakes in drive at any speed right before i ackually stop it feels like its skipping or sucking in and out if u can understand that please any ideas ?????
Old Jan 1, 2009 | 05:27 PM
g_k50's Avatar
g_k50
Did the abs light come on after you replaced the calibers (calipers)? Did you bleed the brakes?
Old Jan 2, 2009 | 06:39 PM
drb1956's Avatar
drb1956
IF you DID bleed the brakes, you might have a warped rotor?? If not the rotors, then the ABS computer is working O/T..you might also look at your rear brakes and check to make sure the drums are not out of round-had that on a van..drove me goofy, trying to figure out the problem-I thought it was the front brakes too...
