Sponsored by: Real Truck
brakes locking up
Old Aug 5, 2014 | 09:07 PM
stewp84's Avatar
stewp84
brakes locking up
I have a 2000 f250 4x4 with 4 wheel abs. The front passenger side caliper keeps locking up while I'm driving and won't release and when I hit the brakes it pulls hard to the drivers side. I have put two calipers on the passengers side and put new brake lines on. Just trying to see if anyone can help.
Old Aug 6, 2014 | 02:34 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Its common for them to stick.
http://www.guzzle7pt3.com/cu.php
Old Aug 6, 2014 | 05:12 AM
redford's Avatar
redford
FTE Leadership Emeritus
If it pulls to the drivers side why are you focusing on the passenger side?
Old Aug 6, 2014 | 06:32 AM
Big-Foot's Avatar
Big-Foot
Sort of like cutting off a board twice and it's still too short!!!
I always replace calipers in pairs along with pads and rotor servicing.
Old Aug 6, 2014 | 06:40 AM
stewp84's Avatar
stewp84
Because the driver side only dose it when the passenger side is sticking.
Old Aug 6, 2014 | 06:51 AM
stewp84's Avatar
stewp84
I have replaced everything the calipers,lines,pads,rotors and hubs on both sides
Old Aug 6, 2014 | 07:45 AM
Big-Foot's Avatar
Big-Foot
Okay Stew - that puts a slightly different light on it then...
Have you checked out the front end of the truck for play in the balljoints and tie rods?
The caliper mounts - if they are slide mounts, you may have some corrosion/rust/wear on the slides which will cause a caliper to hang up and the brake pressure will then be applied un-evenly..
What did the old pads tell you? Are they worn evenly across the face?
Old Aug 6, 2014 | 07:56 AM
stewp84's Avatar
stewp84
I just put new ball joints on it every thing checks out on it. The problem is that it doesn't stick all the time I can drive it for a month or two with no problems then other times it dose it 2 or 3 or more a week
Old Aug 6, 2014 | 08:14 AM
Big-Foot's Avatar
Big-Foot
Floating calipers don't always stick and that may be part of the problem..
The real bad thing is that if the pads have already started a bad wear pattern, there is no economical way to reverse that - you just have to replace them.
Servicing the slides -
Have to remove the calipers, clean the slides thoroughly and use a fine file to remove any rough spots. I use silicone grease to lube the slides. Yes, the grease can attract and hold dirt, but I've not found that to be a problem in normal highway use.
Did you replace both flex hoses on the front?
b_man360
1983 - 2012 Ranger & B-Series
Nov 5, 2011 08:42 AM
nmh2285
Jan 2, 2009 06:39 PM
Ford-Trucker84537
Feb 17, 2007 10:49 AM
blueeyes2478
18
Sep 14, 2005 05:14 PM
JAMC
Mar 21, 2004 06:24 AM
