gota ac/blend door question
Old Jun 4, 2010 | 03:39 PM
hrdfrntr95's Avatar
hrdfrntr95
Question gota ac/blend door question
hey guys....new guy here.....i dont a search on here and i cant find the thread that i found by google so i figured id ask real quick.
i have a 98 explorer limited 302......
just had the ac charged and checked for leaks and nothing found. thats the good news....
ive owned the truck for about a year and over the winter i dont have heat unless i hear this POP sound from inside the dash. and in wisconsin with no heat in the winter SUCKS....
and now that the ac is fixed when i hear the POP sound i loose cool air and get heat....
i know right behind the glove box is a door on a vacuum acuator and i have zip tied it open since when it closes i loose heat. but that isnt the issue. i still hear a POP and loose air...
is there another door somewhere that i need to find and fix? or what could be causing this? is this the "BLEND DOOR" i was reading about? if so where is it so i can replace it?
getting ready to go to mississippi for vacation and dont wana be fighting with the ac down in the south in the dead of summer...
thanks guys/gals
dj
Old Jun 4, 2010 | 09:14 PM
steve(ill)'s Avatar
steve(ill)
read the last two posts and look at the photos
https://www.ford-trucks.com/forums/6...-door-fix.html
Old Jun 4, 2010 | 09:16 PM
steve(ill)'s Avatar
steve(ill)
the vacuum door you zip tied is the fresh air inlet/ cab recirc door that works with "max" AC
Old Jun 5, 2010 | 10:37 AM
hrdfrntr95's Avatar
hrdfrntr95
well i went out to the truck and done some investigating and i guess the previous owner knew about the blend door issues.....the actuator is GONE.....so now i gota buy one of them as well. but my local oriellys has both the door and the actuator in stock and i can get both for around $45.
so now i guess next week end ill either be ripping the dash out or trying to cut the bottom out of the box.....
ghunt
Jul 14, 2020 09:07 PM
ligito
16
May 14, 2016 01:20 PM
rexpedition99
Dec 2, 2015 01:14 PM
Ryland
1997 - 2003 F150
35
Jun 26, 2015 02:54 PM
08superduty08
Jun 22, 2015 08:45 PM
