Sponsored by: Real Truck
2008 Blend door actuator
Old Jun 21, 2015 | 09:40 PM
08superduty08's Avatar
08superduty08
Hello, I have a 2008 f250 lariat with dual zone climate control. When the heat is on, i can hear a ticking sound coming from behind the glove box, I assume this is the blend door motor malfunctioning. The heat works well on both passenger and driver side but the a/c doesn't work on either side. It just blows warm air. Does this mean both of the blend doors are probably bad? Thank you!
Old Jun 22, 2015 | 12:06 PM
droldsmorland's Avatar
droldsmorland
Look at the compressor and see if the clutch is engaged and the compressor is spinning when turned on at the controls. Then go at the blend doors. Not up on the dual zone. I did a write up on the single manual HVAC system on my 08. If I remember I did hear slight clicking as well when it lost its mind. My procedure is in the tech folder here. We should get someone to do it for the dual zone too. Hope this helps.
https://www.ford-trucks.com/forums/1...=droldsmorland
Old Jun 22, 2015 | 08:09 PM
edjunior's Avatar
edjunior
I had the same thing on my '08. Cost me close to $800 to get it fixed. They have to remove the entire dash. I had them replace both doors and actuator motors while they were in there. I wouldn't say it's a common problem, but it does happen often enough if you dig back in the threads.
Old Jun 22, 2015 | 08:45 PM
08superduty08
I read up on some of the previous forums but I couldn't find one with my exact circumstance. Most people who had a problem with the dual zone only had one side that wouldn't work properly. I will check the compressor tomorrow to see if it's kickin on, but I believe it is.
Tobnpr
Jul 28, 2016 09:09 PM
danomac
1983 - 2012 Ranger & B-Series
Oct 2, 2014 08:44 PM
G Ford Fan
Aug 18, 2010 03:59 PM
wolfemax
Jun 4, 2010 09:38 AM
TYZ78F150
May 28, 2010 05:13 PM
