99 Expedition replace blend door - cut hole method
I have a 99 EB Expedition with Auto temp controls. I have no front heat. I replaced the thermostat and the heater hoses about a year ago due to an overheat problem. At the time I also flushed the heater core. Both heater hoses are getting hot when I have the heat on so I don't think my heater core is blocked.
The AC works fine (thank god b/c I am in FL) but I can't hear the blend door or any clicking when I increase the temp to the highest heat setting on a cold morning. So I think maybe the blend door is stuck in the cooling position.
Since I don't hear the clicking of a broken blend door hinge, I was thinking it could be the actuator. In the interest of time and laziness, I was thinking of attempting the "cut a hole behind the glove-box" method to get a look at the blend door operation and to replace it or the actuator if needed.
My question is, can I replace the actuator through the hole, or do I still need to remove the center console?
I replaced my blend door. Used one of those vibrating blade cutters. I had to cut out the plastic top of the bottom air tunnel under the dash to be able to unbolt and install new one. Just put a piece of sheet metal with duct tape back over the tunnel, cant see it. worked fine after install. took a while and lots of scratches.
This video is of an F150, and In the beginning of the video he shows that you have to take off a black cover under the center of the dash to get to the actuator. The F150 did not have a center console, but for my Expy, if it is in the same spot, I would have to remove the center console.
You will still need to get underneath the dash. This is where the blend door motor is. It is flat and square with a shaft that connects to the blend door. You should replace this as well.
