NEW Explorer Blend Door Fix
Old Aug 14, 2007 | 01:32 PM
420troublemaker's Avatar
420troublemaker
Check this out:
http://chrisfransen.com/Ford_Blend_Door_Fix/index.html
Its a new fix for the broken Blend Door on the 1996-1998 Explorers. It's a little different from the others posted out there. My blend door was severly damaged and had to be removed.
Let me know what you guys think.
Old Aug 14, 2007 | 03:43 PM
K2JJB's Avatar
K2JJB
While I like the approach to this you should just use a brand new door instead of fixing the old one. You can get them from NAPA for 10.99 online (NAPA PN is BK 6601810).
I used a similar approach to the one you posted to fix mine over 6 months ago and it is still holding strong.
Old Aug 14, 2007 | 04:49 PM
420troublemaker
Good idea about the new door. I didn't know you could get just the door. Everywhere I looked people had to buy the whole plenum. Then all you would have to do is make the cuts and reassemble.
Old Aug 14, 2007 | 05:10 PM
K2JJB's Avatar
K2JJB
The doors only became available recently (6 or 7 months or so maybe?)... before that I had the same info you did... whole new plenum!
Old Aug 14, 2007 | 08:47 PM
bcjim's Avatar
bcjim
INteresting. I did the "old" method twice and it failed again both times. Maybe I'll try this but since I have heat and max ac works (bypasses the blend door) Im not sure I can motivate myself. Ive sort of learned to live with it.
Old Aug 15, 2007 | 10:13 PM
shiloh66's Avatar
shiloh66
My new blend door came from Car Quest, Dorman brand. I just cut a hole in the bottom of the plenum, installed the new door and then put the piece back in using black RTV. Whole job took about an hour.
Old Jun 4, 2010 | 03:41 PM
hrdfrntr95's Avatar
hrdfrntr95
I CAN GET THIS DOOR AT NAPA FOR $13 but where is it located at to replace??? and pictures of where or what i need to cut out?
Old Jun 4, 2010 | 09:08 PM
steve(ill)'s Avatar
steve(ill)
these photos might help
Free Ford Blend Door Fix
Old Jun 4, 2010 | 09:13 PM
steve(ill)'s Avatar
steve(ill)
good reading
https://www.ford-trucks.com/forums/7...or-repair.html
Old Jun 14, 2010 | 12:04 PM
kwaskow's Avatar
kwaskow
will this procedure help my issue - A/C swiches from panel to defrost/floor
Old Jun 14, 2010 | 09:20 PM
steve(ill)'s Avatar
steve(ill)
no, blend door is temp control, duct selection is controlled with vacuum hoses, dash controller...
Old Sep 18, 2010 | 12:22 PM
mrjay62's Avatar
mrjay62
Thank You all !!!!
I Have a 03 F-250 SD. 130k
I just want to say anytime i have any trouble with my truck i come here !
And you all have just the Right Answers You saved me and im sure countless others Big time Cash!!!
Again Thanks to all on this site!!!!!
Thanks
Jay
rlester
Jul 21, 2011 02:33 PM
mbranagan
Oct 30, 2010 07:23 AM
Sweeper
Feb 11, 2009 01:15 AM
jfrank
70
Sep 15, 2003 10:25 PM
