Check engine light.
Old Jun 8, 2010 | 08:54 PM
bismic's Avatar
bismic
<TABLE style="WIDTH: 524pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=699 x:str><COLGROUP><COL style="WIDTH: 524pt; mso-width-source: userset; mso-width-alt: 24704" width=699><TBODY><TR style="HEIGHT: 13.6pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ff99cc; WIDTH: 524pt; HEIGHT: 13.6pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 width=699>From your diesel supplement manual</TD></TR><TR style="HEIGHT: 274.45pt; mso-height-source: userset" height=366><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ff99cc; WIDTH: 524pt; HEIGHT: 274.45pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=366 width=699>The 5 yr / 100k warranty coverage (per the manual, page 7) includes the following:
Engine and these components:
cylinder block
heads and all internal parts
intake and exhaust manifolds
timing gear
harmonic balancer
valve covers
oil pan and pump
water pump
fuel system (excluding fuel line and fuel tank)
high pressure lines
gaskets and seals
glow plugs
turbocharger
PCM
electronic driver unit
injectors
injection pressure sensor
high pressure oil regulator
exhaust backpressure regulator and sensor
camshaft position sensor
accelerator switch
</TD></TR><TR style="HEIGHT: 219.4pt; mso-height-source: userset" height=293><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ff99cc; WIDTH: 524pt; HEIGHT: 219.4pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=293 width=699>Furthermore, (under emissions warranty), you will not be charged for labor, diagnosis, or parts for any emissions control device or system for 100k (ie no $100 deductible):
Air flow sensor
Air Fuel Feedback control System and sensors
Cold start enrichment system
Electronic engine control sensors and switches
EGR system
Exhaust manifold
Fuel Injection System
Intercooler Assembly - Engine Charger
Power Train Control Module
Turbocharger Assembly
Also covered by the two emissions warranties (Emissions defect warranty and Emissions performance warranty):
All emisssions-related bulbs, hoses, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines and wiring harnesses that are used with components on the list above.
</TD></TR></TBODY></TABLE>
Old Jun 8, 2010 | 08:55 PM
bismic's Avatar
bismic
Link to the manual if you do not have one:
http://www.motorcraftservice.com/vdi...pageid=&gutsid=
Click on "Owners Guides" in the left hand menu and drill down to your vehicle specific manual.
Old Jun 8, 2010 | 09:12 PM
MIKE1646's Avatar
MIKE1646
I will be taking care of that first thing in the morning.
Old Jun 8, 2010 | 09:13 PM
gearloose1's Avatar
gearloose1
Sometimes, I hate to say this.. but for $100.... the cetane boost would not be included.. that is a good chunk there.
Old Jun 9, 2010 | 09:14 PM
MIKE1646's Avatar
MIKE1646
Dealer wouldn't reason I called Ford, check will be here in 7 to 10 days. Thanks for all your help guys you save me 100 dollars.
Old Jun 9, 2010 | 09:22 PM
bismic's Avatar
bismic
Think about spending a little of the refund and become an FTE supporter ......
Not sure why some dealerships charge the $100 and others don't (I have my suspicions though). All I know is that I will go to the ones that don't make you go through the refund hassle!
Old Jun 10, 2010 | 07:35 PM
MIKE1646's Avatar
MIKE1646
You're right Mark FTE supported here.
I called three more dealers in my area to see if they would charge the deductible on a EGR replacement and they all said yes
Old Jun 10, 2010 | 07:37 PM
MIKE1646's Avatar
MIKE1646
Duplicate post
Old Jun 10, 2010 | 08:25 PM
npccpartsman's Avatar
npccpartsman
And what was their response when you told them that the repair was FREE because it's emissions related??
Old Jun 10, 2010 | 08:35 PM
MIKE1646's Avatar
MIKE1646
Nothing just that I would get the check and no apology. I guess they didn't like that I called Ford. There was no point in telling the other dealers
keninwa
2009 - 2014 F150
Jun 30, 2016 12:32 PM
oxt127
Apr 30, 2016 05:51 AM
mikeismadness
1978 - 1996 Big Bronco
Jul 27, 2011 03:59 PM
2Fords1Jeep
Sep 14, 2005 04:53 PM
lowec
Mar 6, 2004 10:02 AM
