96 explorer check engine light
Old Mar 6, 2004 | 01:24 AM
lowec's Avatar
lowec
I have a 1996 explorer with the check engine light on. It is reading code P0420,P0153,P0133. Does anyone know if replacing oxygen sensors will cure this. Any suggestions ?
Thanks Bryan Lowe
Old Mar 6, 2004 | 02:11 AM
Opera House Works's Avatar
Opera House Works
How many miles on this and do you have any other engine problems. The upstream sensors have a slow response. This is a real sensor fault and about the only valid reason you should change O2 sensors. Have you been loosing coolant lately? I would replace the upstream sensors first and see if that corrects the problem. Have you had the light on for a long time? The other code indicates a failing cat converter. The three codes as a group indicate things are being contaminated. Is it burning a lot of oil?
Old Mar 6, 2004 | 10:02 AM
lowec's Avatar
lowec
I have 137,000 miles. I don't lose any coolant & doesn't burn oil. The light has been on for about 10,000 miles.
Thanks Bryan Lowe
tbush08204
Jan 20, 2016 07:29 AM
MRStace84
13
Dec 16, 2015 04:50 PM
bronkntrukholik
Jan 20, 2013 06:29 AM
bae77345
Dec 8, 2004 09:05 PM
jtbpe
May 23, 2004 02:38 PM
