Sponsored by: Real Truck
2001 trailer brake controller
Old May 29, 2010 | 11:49 PM
cykoticford's Avatar
cykoticford
Hello does anyone know if someone makes a wiring harness to put a factory 2007 in dash brake controller in the dash of a 2001 f-250? Or will it plug right in to my plug under the dash?
thanks jeffrey
Old May 30, 2010 | 12:56 AM
TennesseeMustangPerf's Avatar
Much better off just getting a good aftermarket unit such as the Tekonsha Prodigy or P3. The OEM is a TON of work to retrofit, not as easy as plug and play. It is routed through the ECU and get's it's control readings VIA the master cylinder. Lot of stuff has to be changed out, if even possible.
Old May 30, 2010 | 01:58 AM
TexasRebel's Avatar
TexasRebel
even if you get the electrical fiasco solved, where would you put the controller? ...the dash changed completely in 2005
Old May 30, 2010 | 02:05 AM
cykoticford
in the pocket beside the steering i have the pocket and i think thats where they put them on the 05 06 07
cstock
All Things Towing
May 1, 2013 01:11 PM
rocknrod
1997 - 2003 F150
Dec 5, 2012 08:27 PM
michael cook
2009 - 2014 F150
15
Jun 27, 2011 12:14 AM
aceltx09
Nov 7, 2010 09:22 PM
wolfmanagh
Feb 19, 2005 02:56 PM
