Sponsored by: Real Truck
brake control harness
Old Feb 19, 2005 | 01:29 PM
wolfmanagh's Avatar
wolfmanagh
Where does the supplied harness for the power brake control plug into under the dash on my 2001 f250. The cute little sticker on the plug reads "connect to instrument panel feed".
Old Feb 19, 2005 | 02:09 PM
mwpierson's Avatar
mwpierson
wolf:
I have an 02 but I think the plug is in the same place. Take off the panel under the steering column. Then on the far right of the opening, look up inside between the stereo and the 4x4 selector switch and it's attached to a sheet metal bracket.
HTH,
Mike
Old Feb 19, 2005 | 02:56 PM
wolfmanagh's Avatar
wolfmanagh
Thanks, I found it right away with your description. That plug is way in there. And it was behind my aux idle control wiring. I asked here cause I figured I'd get a quick answer and I did.
windindaface
Dec 21, 2012 01:22 PM
chaser1602
1997 - 2003 F150
Apr 4, 2012 09:09 AM
1979F-150Man
Mar 14, 2012 12:30 PM
browntown3
Aug 23, 2008 05:23 PM
leroys4wd
1997 - 2003 F150
Jul 13, 2004 12:41 AM
