not realy sure if it is a miss it is iratic dont know when i will happen but the check ingen light will come on and sodenly no power and the moter shakes wile it is doing it i have checked the fuel presher 55psi hpop pressur 800 at idel 3200 topend. replaced oil senser in head replaced cps did not help any suggestions
map sensor is up high on the hood to firewall seal area. has a plug and rubber hose coming out of it. or just follow the little rubber hose off the intake plenum to the pass side and youll see it.
