Sponsored by: Real Truck
missing and no power with the check engine light
Old Feb 10, 2010 | 11:12 AM
leerider524's Avatar
leerider524
I have a 2002 f250 7.3 4X4 w/ about 107,000, it's missing and no power with the check engine light on, when we put the decoder on it, it says no codes passed all test and I have replaced the fuel filter I have no clue, any ideals would be great
Old Feb 10, 2010 | 11:20 AM
Pocket's Avatar
Pocket
The code reader you used is not compatible with Powerstrokes. Most generic code readers don't work on these trucks.
From the description of your problem, my first guess would be the UVC harness. It's a common problem with symptoms as you describe. Under each valve cover, the harness easily works itself loose over time. Ford has plastic tabs for the original harnesses to lock it in place, and new UVC harnesses are updated to correct the problem. Plastic tabs are much cheaper though.
However, without pulling the codes, it's a guess at this point. Best bet is to find a PSD compatible scanner and go from there.
Old Feb 10, 2010 | 11:50 AM
leerider524
when pulling the valve cover is their any gaskets that i have to replace and where do i get the clip for the UVC harness
Old Feb 10, 2010 | 12:02 PM
Pocket's Avatar
Pocket
Nope, the valve cover gaskets are re-useable.
Ford dealership. About $8 for the package, and has 3 small clip inserts in there along with install instructions.
Old Feb 10, 2010 | 03:35 PM
leerider524
I pulled the valve cover and looks like the plugs are the new ones they have a wire that flips up and keeps it from comeing unpluged
Old Feb 10, 2010 | 03:46 PM
Pocket's Avatar
Pocket
You're looking in the wrong spot. What you see are the wires that connect to the individual injector solenoids. Only those have the wire clips.
The UVC harness is where the wiring harness first goes under the valve covers. There are actually two separate harnesses. The one hidden directly under the valve cover is what pops off. Check those connections to see if they are loose.
Old Feb 10, 2010 | 03:52 PM
leerider524
that was backed out cool hope that will fix it glade I didnt get it back together yet ill let you know if its fixed
Old Feb 10, 2010 | 03:58 PM
clem1226's Avatar
clem1226
here is a link to a fix that only costs $.50 cents.
https://www.ford-trucks.com/forums/9...-cent-mod.html
IE the fifty cent mod, it will keep those UVC plugs nice and tight.
Old Feb 11, 2010 | 08:20 AM
leerider524
That fixed it, thanks for the help went to ford and bought the clips and got it back togther runs good thanks agin
Old Feb 11, 2010 | 03:56 PM
_Rick_'s Avatar
_Rick_
Leer,
Only out of curiousity. What did Ford charge for the clips?
Hope not too much more than a quarter.
Rick...
Old Feb 11, 2010 | 04:29 PM
leerider524
They were $12.99
Old Feb 11, 2010 | 05:22 PM
_Rick_'s Avatar
_Rick_
Ouch, but I know what it's like when you just don't want to mess around with fabrication (even if only a quick grind of a quarter) or don't have time. Sometimes it's just nice to go OEM.
Rick...
They were $12.99
Old Feb 11, 2010 | 06:22 PM
Pocket's Avatar
Pocket
Damn, the charged me $8 for mine. But then again, the people at the parts counter knew me, and they were getting ready to shut down the dealership, so they probably gave me a discount or something.
At any rate, glad you got it fixed. And glad it was something simple.
roboa89
2004 - 2008 F150
19
Apr 6, 2016 06:20 PM
Cory West
1997 - 2003 F150
Sep 24, 2015 07:50 PM
motorhead704
Dec 27, 2014 01:10 PM
varminthunter243
19
Dec 4, 2014 06:13 PM
