Sponsored by: Auxito
Check engine light and no code
Old Feb 10, 2010 | 10:59 AM
leerider524's Avatar
leerider524
Exclamation Check engine light and no code
I have a 2002 f250 7.3 4X4 w/ about 107,000, it's missing and no power with the check engine light on, when we put the decoder on it, it says no codes passed all test and I have replaced the fuel filter I have no clue, any ideals would be great
Old Feb 10, 2010 | 01:53 PM
kaboom10's Avatar
kaboom10
Clean the MAF w/ MAF cleaner, check the air filter, replace the PCV and make sure the hose is not leaking for they tend to leak in the back where u can't see them. Tighten all the clamps in the inlet system also.
Old Feb 10, 2010 | 03:26 PM
projectSHO89's Avatar
projectSHO89
Start with a better scanner....
If the MIL is on, there is one or more DTCs stored in the PCM. Cheap code readers generally cannot access the more advanced manufacturer-specific fault codes.
Old Feb 10, 2010 | 03:42 PM
leerider524
I had one from Mac and im not sure but I would think that it was a pretty price one and it said no code were stored
Old Feb 11, 2010 | 08:21 AM
leerider524
Got it fixed, the plug under the vavle cover backed out runs good now
Old Feb 11, 2010 | 09:08 AM
kaboom10's Avatar
kaboom10
Did u put a LITTLE dab of antisieze on it?
Old Feb 11, 2010 | 04:32 PM
leerider524
No DC111 and the clip ford came out with to keep it together hope it will be ok
troposcatter
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 5, 2016 01:07 AM
Jer2000/2.5
1983 - 2012 Ranger & B-Series
18
Oct 26, 2009 10:21 PM
4x492150
May 6, 2009 08:39 AM
97 ranger 1
Jun 26, 2005 07:04 PM
gizmo13
Aug 14, 2004 07:58 PM
