1994 Powerstroke GP issues
Old Nov 26, 2011 | 09:01 PM
broodog's Avatar
broodog
Replaced all 8 GP's, the GP unit itself, checked all fuses. The glow plugs are still not working. Checked the GP unit power is not getting across when the key is on. Is there any fuses I'm missing? How about the relays inside the engine bay fuse box, what are they for? Any help is greatly appreciated
Old Nov 26, 2011 | 10:39 PM
bad12jr's Avatar
bad12jr
I assume your calling the gp unit the relay? Take your relay in top of the motor and apply twelve volt to the very small post. This should make the relay function with just a click. If that doesn't work then the relay is bad or wrong for the application.
Where did you get it and what part number. What brand and part number gp's did you use as well? The pcm supply low amp power to control the relay but I don't remember 100% if its fuse linked.
Old Nov 26, 2011 | 11:10 PM
broodog's Avatar
broodog
Had this problem before i replaced the gpr so I thought it was the gpr but no luck where would the fuse link be?
Old Nov 26, 2011 | 11:47 PM
pjwoolw's Avatar
pjwoolw
Do you have 12 volts on the hot side of the GPR?
Old Nov 27, 2011 | 06:03 AM
broodog's Avatar
broodog
Not sure about 12 volts but one Side is hot so I'm assuming it's 12 volts
Old Nov 27, 2011 | 08:16 AM
Hussler's Avatar
Hussler
Fuse #22 supplies power to the GPR coil.
Does the WTS light work ... if so then fuse #22 is OK?
The 1 big wire on one of the big lugs should be hot or ~ 12 volts all the time. It is protected by a fuse link located near the starter relay where this 1 big wire connects to. The other big lug should be hot or ~ 12 volts when key is ON (relay pulled in). The two smaller wires control the coil of the relay ...
One of the smaller wires is hot or ~12 volts with key ON. The other smaller wire is pulled to ground by the PCM to activate the relay coil.
Try this ... disconnect both smaller wires. Jumper one of the smaller relay lugs to battery plus and jumper the other smaller relay lug to a ground. The relay should pull in and you should hear a click. If so the relay is working.
Here is a diagram ...
Old Nov 27, 2011 | 08:18 AM
bad12jr's Avatar
bad12jr
Run a jumper wire and see if there is power to the other side of the relay. Make sure that the system is working then start tracing back.
Old Nov 27, 2011 | 08:33 AM
Ken_C's Avatar
Ken_C
had to go copy and paste this from another similar post:
the best way I have found to check the gpr is to test it with a cold engine and a volt meter. turn the key on and check the 2 small posts of the gpr if you have 12 volts there that means the relay is in fact on. now that you know for sure the gpr is on, check the volts across the 2 large terminals. with the relay on there should be 0 volts or a very small fraction of 1. any reading you get during this test is the amount of volts that are NOT getting to the glow plugs. any significant reading and I would place my order for a new GPR.
Old Nov 27, 2011 | 09:24 AM
broodog's Avatar
broodog
Thanks for all the great responses! Another issue I have is my engine is missing so I know I have atleast 1 injector out. Is there anyway to check without pulling them? Maybe a laser heat gun on the exhaust manifold at each?
Old Nov 27, 2011 | 01:05 PM
broodog's Avatar
broodog
Also I tested the small bolts on the gpr and neither is going hot with key on
Old Nov 27, 2011 | 02:18 PM
Hussler's Avatar
Hussler
Laser heat gun is a good test if engine is cold.
Think you found your problem on GPR. The Red/Lt Grn wire should be hot with key on. Nothing magic about it, it's just a wire that goes from the small bolt you mentioned, through the 42 pin connector to fuse #22. Since the truck runs we know fuse #22 is OK so it's somewhere in-between.
Old Nov 27, 2011 | 02:28 PM
broodog's Avatar
broodog
Is there a fuse link in that wire too?
Old Nov 27, 2011 | 02:48 PM
Hussler's Avatar
Hussler
No, fuse #22 30A protects it. Refer to the diagram above and you can see where connector B on the GPR goes thru the 42 pin connector - pin 35 - then to a fuse. That is fuse #22. From you observations a wire is broken somewhere along the route or maybe bad connection to the underside of the fuse block.
Note: I did get your PM and will see if I can send you a better diagram on e-mail. Might have to wait until tomorrow until I'm on another computer and can do some PDF conversions.
Old Nov 27, 2011 | 05:03 PM
broodog's Avatar
broodog
Can I just run a new wire or should I try and find the broken wire and repair it?
Old Nov 27, 2011 | 06:58 PM
bearhugger's Avatar
bearhugger
When you said you were not getting voltage on either side of the little wires,were you checking across the wires are checking each one to ground.
