Pitman arm loose
Old Feb 3, 2003 | 07:06 PM
fordlowboy's Avatar
fordlowboy
Exclamation Pitman arm loose
My pitman arm is loose on my 78 150 4x4. It is the splines on the shaft or the pitman arm it self. The nut is tight, but it still slops. Any ideas on a good, but quick fix?
Old Feb 4, 2003 | 01:34 AM
Torque1st's Avatar
Torque1st
Posting Legend
Pitman arm loose
Sorry, but it sounds like replacement time.
Old Feb 4, 2003 | 06:28 AM
macguyver's Avatar
macguyver
Pitman arm loose
I agree with T1. If the nut is tight it shouldn't slop. It's a tapered spline.
Old Feb 4, 2003 | 12:44 PM
beartracks's Avatar
beartracks
Pitman arm loose
Sounds like the arm for sure is worn, worse it may have ruined the splines on the steering gear shaft.
On a side note. Anyone know off hand if the pitman arm fits on only one way or can you move it around to center the steering wheel/lock to lock turns? Mine is a 1/2 ton.
Old Feb 4, 2003 | 05:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Pitman arm loose
Bear-
You asked:
The pitman arm is aligned with the internal centering mechanism in the power steering unit. It should not be moved. If the steering is not centered lock-lock there is another problem which should be repaired.
Old Feb 4, 2003 | 06:02 PM
85351ho's Avatar
85351ho
Pitman arm loose
it should be splined so you can only chane it in 90 degree incriments
Old Feb 4, 2003 | 06:58 PM
fordlowboy's Avatar
fordlowboy
Pitman arm loose
thanks for the help.
Old Feb 6, 2003 | 09:43 AM
beartracks's Avatar
beartracks
Pitman arm loose
Thanks also from me. The correct fix for me would probable be to reassemble the toe end collor adjuster in a different orientation. i.e. screw it on one side a way before starting the other.
awjjim
Apr 6, 2014 09:08 AM
Pappys53
15
Nov 27, 2010 11:48 AM
Kickinbass23
Aug 5, 2010 02:47 PM
bmacky14
Jun 22, 2009 08:41 AM
Weldmen
Aug 6, 2006 11:06 PM
