Pitman Arm ?
Old Jun 17, 2009 | 11:30 PM
bmacky14's Avatar
bmacky14
Pitman Arm ?
tomorrow i gotta take my pitman arm off and switch it with a 4 inch drop pitman arm for my suspension lift is the pitman arm hard to take off or do i need any special tools any suggestions ?
Old Jun 18, 2009 | 12:38 AM
Dirt racer's Avatar
Dirt racer
Yes you will need a pitman arm removal tool. Has two fingers that reach around it and a threaded shaft in the middle. Maybe you could rent one from a parts place.
Old Jun 18, 2009 | 03:22 AM
goodB0Y's Avatar
goodB0Y
They can be a PITA to remove sometimes... might need a BFH and set of torches to heat it up as well....
Old Jun 18, 2009 | 08:27 AM
Diesel_Brad's Avatar
Diesel_Brad
Dont beat on the shaft too hard. You will ruin the bearings.If you want to take the piman arm off and dont care about saving it. You can deeply score the pitman arm in 2 spots(almost thru) and tap it w a small hammer. It will fall off, literaly
Old Jun 18, 2009 | 11:30 AM
bmacky14's Avatar
bmacky14
alright and installation is easy ? and i will probly be switching my left and right inner tie rod at the same time
Old Jun 18, 2009 | 12:24 PM
Lazy K's Avatar
Lazy K
Good advice from everyone. When I took the arm off my `87 I was lucky, a big pry bar and a few good blows with a hammer on the side of the arm boss while hanging on the bar and it came off.
Refitting is a breeze, it just slides on by hand and tighten the nut.
Old Jun 18, 2009 | 08:06 PM
Jonas1022's Avatar
Jonas1022
What about post replacement alignment? Is that necessary with Pitman arm R & R?
Old Jun 18, 2009 | 08:30 PM
92 f-150's Avatar
92 f-150
USE HEAT!!!!!!!!! that is all.
Old Jun 20, 2009 | 03:06 PM
bmacky14's Avatar
bmacky14
ya still cannot get it off its on there good
Old Jun 20, 2009 | 03:11 PM
92 f-150's Avatar
92 f-150
More heat!!!!! And a bfh.
Old Jun 20, 2009 | 03:30 PM
Diesel_Brad
NO not heat! all that does is get the shaft hot and ruin the seal. Do you have a puller? if so, when you have ALOT of tension on it, hit the end of the puller you put the socket onto. If that does not work do what i said earlier and deeply score the pitman arm on two sides (almost thru) then hit the cut spots w a chisel. the old pimpan arm will split in two and be off
Old Jun 20, 2009 | 09:31 PM
92 f-150's Avatar
92 f-150
yea i suppose. i used alot of heat because the seals on my gearbox were already ****ed.
Old Jun 21, 2009 | 12:00 PM
bmacky14's Avatar
bmacky14
i got the puller but whenever i get it a lil bit tightened it pops off but i hear theres a better pitman arm puller that a buddy of mine has that he uses for gettin rv pitman arms off if that doesnt work ill proply be cutting it or scoring it
Old Jun 21, 2009 | 02:04 PM
rikard's Avatar
rikard
Heres a tip. Get two (2-3lbs) hammers. Hold one against the the part. Hit the part with the other hammer directly opposite. When I have to bust a pipe union I do the same thing, except with pipe wrenchs. I use PB Blaster, Kroil, WD40, and ATF.
Sounds like the threads are stripped on your puller.
Regards and Happy Fathers Day
rikard
Old Jun 22, 2009 | 08:41 AM
tecgod13's Avatar
tecgod13
If the puller is popping off, its either the wrong size, or its not on straight.
When I had to do the seals on my ranger, I didn't think I'd be able to get it off either. I was using a puller, and tightened it up as much as I dared, still didn't come off. For some reason I ended up taking a break at that point (had to go to work, or sleep or something), when I went back to it the next day, the puller was loose and I was confused. Went to tighten it again, and the pitman had loosened up and came right off. So try tightening it up and waiting a while.
2001SuperDuty
Jan 31, 2019 01:12 AM
jerryst
Nov 15, 2016 09:10 PM
caminokid863
1997 - 2003 F150
May 9, 2015 09:09 AM
Pappys53
15
Nov 27, 2010 11:48 AM
sdg0080
1978 - 1996 Big Bronco
Oct 5, 2010 11:15 AM
