Pitman Arm thread size
Old Mar 27, 2014 | 04:45 PM
awjjim's Avatar
awjjim
For my, 1949 F4 would anyone know the thread size for the pitman arm nut. Thanks
Old Mar 27, 2014 | 07:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
it's a 7/8-14, same for almost all from F-1 and up
Old Mar 28, 2014 | 05:45 AM
awjjim's Avatar
awjjim
I should have been more clear. The threads on the shaft that comes from the gear box and the pitman arm attaches to. Appears to be 7/8-??
Old Mar 28, 2014 | 09:59 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, it's a 7/8"-14 threads per inch
Old Mar 29, 2014 | 02:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
351153-S .. Nut-Pitman Arm to Shaft 7/8" -14 / Obsolete
DON SANDERSON FORD in Glendale AZ has 3 = 623-842-8643.
HAVEN FORD PARTS in Haven KS has 4 = 620-465-2252.
NOS PARTS LTD in Waxahachie TX has 10 = 972-937-2201.
Old Apr 6, 2014 | 09:08 AM
awjjim's Avatar
awjjim
Bill,
I have decided to go through the steering gearbox, 1949 F4. Would you have the part numbers and possible source for the following:
2/each sector shaft bushings
1/each lower bearing cup and bearing
1/each upper bearing cup and bearing
1/each shaft/worm gear assembly
I got the oil seal spec from your previous post.
I appreciate your help to me and all others. Jim
the gruffalo
18
Sep 8, 2015 01:00 AM
rkeasler
Sep 18, 2007 05:36 PM
01f350
Mar 23, 2007 09:45 PM
92 f150300six
Dec 13, 2003 10:39 AM
