DFA Regulated Return Question
Old May 28, 2010 | 07:28 AM
03_PSD's Avatar
03_PSD
I've just installed the RR portion to the CCK, Dino Fuel Alternatives sales. My fuel psi rose to 100 after my install. Before it was at 63-65 psi. The fuel sender is in the bottom port on the fuel bowl. Is there something wrong, truck starts fine runs normal, little better peddel response, and tad quiter. When I get off work I'll remove the sender from the fuel bowl and move it to the RR port and see if that changes. Oh and just for the record I didn't adjust the RR, installed it right out of the box.
Old May 28, 2010 | 07:42 AM
Izzy351's Avatar
Izzy351
I had to adjust mine down as well. It went up to about 85psi from 62 or so at the bowl (post filter). I would adjust it if I were you. I have mine sitting at 65 right now. You run the risk of blowing O-rings keeping it that high.
Old May 28, 2010 | 07:56 AM
03_PSD's Avatar
03_PSD
I knew it wasn't good...lol I'll try to adjust it, exactly what needs to be adjusted. I don't have the papers at work.
Old May 28, 2010 | 10:36 AM
Izzy351's Avatar
Izzy351
You have to loosen a nut and the body, adjust it, then tighten the nut again. I'm out in the field right now or I'd be more specific. Sorry......
Old May 28, 2010 | 11:01 AM
03_PSD's Avatar
03_PSD
I follow what your saying, thanks Joe!!
Old May 28, 2010 | 02:36 PM
03_PSD's Avatar
03_PSD
Got it Joe, thanks for the help bud!
Old May 28, 2010 | 04:45 PM
Izzy351's Avatar
Izzy351
Good deal...
derek0525
Jan 11, 2016 03:55 AM
Diesel Submariner
39
Aug 7, 2015 01:11 PM
sowaxeman
Mar 23, 2015 08:00 AM
endobear
Mar 17, 2015 11:16 PM
bdpotts
Aftermarket Products
Aug 27, 2014 04:53 AM
