I have an 8.5 x 20 enclosed trailer. I do sound/light/staging production - and currently it weighs in at 6500lbs. Soon it will get to be more like 9k. It's a dual 5200lb axle.
Is this F150 territory or do I need a superduty? I do this 2 times per month on average - usually short trips (30 miles each way) and a couple times per year I go 100 miles each way.
At least a 350SD, preferably a 450 if you are that loaded 24/7/365.
Why? It's within the capacity of an 04+ F150. He already said it's just a couple of times per month. Regardless, a 350 is overkill and a 450 is rediculous. 250 SRW will be more than enough. Diesel, gas, whatever, it doesn't matter.
Thanks!
With the information so far, I'd say, you're on the fence. Do you want/need a crew cab? If yes, then no question... you have to go SD in my mind. The half ton crew cabs don't have enough payload to have a loaded crew cab and truck bed...in addition to pulling a trailer like that.
If you don't need a crew cab...and can go regular cab, or just super cab. Then I think an F150 with the HD payload would be pretty attractive.
I am going to say no! You don't NEED a superduty. I know a guy that pulls 6000lbs with a mini van on trips that are 220 miles, and he has been doing it for 250,000 miles with multiple brands. I don't condone this type of behavior, that is not what I am saying. A properly setup 150 will pull that without a problem. It just depends if you want a superduty body style or not. I like the idea of over kill but it is not necessarily. So go out and drive one and see if you like it and let that be the judge not your trailer.
While an F-150 can be equipped to handle the trailer you tow, a Super Duty will tow it much better. Having a heavier truck under you, with better brakes and better suspension, makes all the difference when you get into bad weather, high winds, tour buses blowing past you at 80 MPH and stuff like that.
A 2005+ truck with a 5,4L engine and 5R110W transmission will handle the load just fine. Find one with 4.10 gears if you tow in mountain areas. My truck (see sig) regularly tows a 28 foot enclosed car hauler (around 8000 pounds) without any issues.
