problems with my 6.0
Old May 20, 2010 | 11:51 PM
ford6.0sd's Avatar
ford6.0sd
i bought a 2004 ford f250 S.D 6.0 diesel about a year ago. with in the last 2 months i been havein problems. sometimes when im driveing it ill come to a light and have to stop, when i go to take off my truck will be running but i will have no power. after about a min. the power is back and i can go. now im havein problems with in staying running, ill let it run, but if it sits to long the truck will start to shake then stall. this only happens when i come to a stop, or just let it run. i dont no alot about diesels (this is my first) what do you think is wrong with my truck and what should i do???? anyting will help.thanks, brett
Old May 21, 2010 | 06:52 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Have you run a scan tool to check for DTCs? Any smoke?...What color? Check you batteries...load test them...should be at least 12.6v...Could be the FICM....also pull both fuel filters and check them for debris....then purge the system of air by cycling the KOEO three times at 30 second intervals...Any chance someone put Gasoline in your fuel cell? Could have a pressure leak....Turbo could be coked up...EGR valve may need pulled and cleaned....when was the last oil change?
Old May 21, 2010 | 06:58 AM
texans's Avatar
texans
HPO leak, or any of the things moyock said. I would start by getting the codes read (you can have codes with out a cel). Then, depending on what kind of codes you find, pull the egr valve out and clean it. Test the FICM, there is a great write-up in the tech folder of this section that explanes how to do this.
dubcnea
Apr 8, 2014 10:49 AM
ford6.0sd
May 20, 2010 11:46 PM
85F_150driver
Nov 11, 2007 04:30 PM
1976 drag
Jun 5, 2005 09:06 PM
gsmc
Oct 15, 2001 08:12 AM
