gearshift lever won't move
Old Feb 2, 2003 | 08:47 PM
jonjamky's Avatar
jonjamky
I can't get gear shift lever out of park.Anyone have any idea what is wrong
Old Feb 2, 2003 | 09:03 PM
buzzard's Avatar
buzzard
Man, I hate to do this, BUT after having to rescue my wife one time, I feel obligated to ask, do you have the brake pedal depressed?
Like I said, my wife (yes she's a blonde) called me one day and said she couldn't get her car into a gear. I dropped what I was doing and raced to see if I could help. I jumped into her car started it, pushed the brake pedal and grabbed the shift lever. I expected it to meet me with great resistance, but much to my surprise it slid right into gear so I asked her if she had depressed the brake and she said she must have forgotten...it's a good thing she's do damn pretty.
Old Feb 3, 2003 | 12:10 AM
Racerguy's Avatar
Racerguy
Try turning the key to the off position....not to lock and then see if it moves. If it does the solenoid that works the interlock isnt working. Could be faulty or could be just a fuse.
Old Feb 3, 2003 | 08:26 PM
rbeitz_1's Avatar
rbeitz_1
Check to make sure your brake lights are working. If you don't have a blown fuse then the problem is in the multi-function switch located on the brake pedal itself. Try fiddling with the connection to make sure the wires are tight. This same thing happened to me and all I had to do was jiggle the wires and it started working again. Been OK now for about 10K miles.
I work around is to just turn the key to the first postion and move the shifter to nuetral. You can then start the vehicle and put it in drive. However, if the multi-function switch is not working you will not have any brake lights. So be careful if you drive it this way.
Old Feb 6, 2003 | 05:31 PM
jonjamky's Avatar
jonjamky
Thanks for all of the input on my gear shift problem.It was a bad brakelight switch.Total costfor part 20.85.This site,as always ,has been a very valuable link to an inexpensive repair.
Old Feb 9, 2003 | 08:03 PM
rbeitz_1's Avatar
rbeitz_1
Red face gearshift lever won't move
Glad to hear it was a simple fix!!
Old May 21, 2003 | 07:56 PM
upinheeaa's Avatar
upinheeaa
Thank you for the excellent information in this thread!
I experienced this same problem in my 97 F150 and investigated the brake pedal switch based on your suggestions. Found that when the truck was manufactured, the wire harness had been pulled a little too tightly and the movement of the brake pedal was just enough to strain the connection on the connector. Upon closer inspection I found that the wire had been completely severed and was only being held by a small portion of the shielding.
I totally removed the 2-prong, female connector that Ford supplies and added my own connectors using simple shielded speaker connectors.
8 cents + 20 minutes of research sure beats the $140 the dealership wanted.
Thanks again.
jmuenchow
Jun 1, 2018 03:45 PM
youngblood1989
Aug 17, 2016 05:13 PM
Guardianangel5699
Feb 21, 2016 02:35 PM
Ryland
1997 - 2003 F150
Oct 22, 2015 09:13 PM
Jeff66
Dec 30, 2009 09:12 AM
