78 automatic shift lever
Old Aug 17, 2016 | 04:12 PM
youngblood1989's Avatar
youngblood1989
On my 78 custom, the shift lever is very loose on the shift collar. The shop manual showed a grommet so I bought that but now I realize I don't have the same type of shifter lever. Most I have seen are round so the grommet fits around them and into the hole on the shift collar, but mine is square at the end and doesn't use a grommet? Is this the original column?
Old Aug 17, 2016 | 04:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978 A/T shift lever
Most I have seen are round so the grommet fits around them and into the hole on the shift collar, but mine is square at the end and doesn't use a grommet.
Parts catalog pic without tilt wheel (lever has a square end - see pic below) does not show a grommet.
Old Aug 17, 2016 | 05:05 PM
youngblood1989
Thank you! For whatever reason my 78 ford shop manual shows the grommet for both tilt and non tilt wheels. So it looks like I'll need a new shift collar, since the pin is in good shape but the holes in the collar for the pin are ovaled.
Old Aug 17, 2016 | 05:13 PM
NumberDummy
So it looks like I'll need a new shift collar, since the pin is in good shape but the holes in the collar for the pin are ovaled...a common occurrence.
D9TZ-7228-B (replaced D8TZ-7228-B) .. A/T Shift Collar-Use without Tilt Wheel / Obsolete
1978/79 F100/350, Bronco & Econoline.
If it's not available from auto parts stores:
PHILLIPS FORD in Phillips WI has 1 = 715-339-3045.
GILLIAM MOTORS in Dillwyn VA has 1 = 434-983-2026.
B. F. WHITE MOTOR CO. in Stanton TX has 1 = 800-953-3321.
DEWEY MOORE FORD in Hughes Springs TX has 1 = 903-639-2516.
D8TZ-7228-B =
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
The Masked Rider
Oct 27, 2020 07:56 AM
tvliftcabinet
28
Apr 12, 2017 05:48 PM
drabina
Oct 24, 2016 04:05 PM
Dylan518
Jul 9, 2016 01:07 PM
Shadowrider123
Apr 19, 2015 09:57 AM
