6-speed controller?
Old Oct 11, 2010 | 10:38 PM
  #31
Muel's Avatar
Muel
Originally Posted by Mudd460
I'm not sure I understand, you build Fords, but you are here asking about the transmissions? You should have a direct pipeline to all the answers you might need. With A plan, you get 3 percent under invoice plus incentives, how could you look elswhere for a truck?
Zero experience with this transmission, asked around got nothing came looking for others experience. Was this a singular instance, I've received enough feedback to know that there are serious problems with this gearbox but not all of them. The 6-speed is simply not used in what I typically do, and I know why it is going to stay that my in my buisness.
For a nobody, I can access HP/Race info though I typically use few Ford Parts and even less often do I buy them from Ford. I've got nothing on the consumer side, no need.
Ford is not the only place I can kill the invoice, just walk in with cash.
Old Oct 11, 2010 | 11:34 PM
  #32
Powerdude's Avatar
Powerdude
This sounds like the drive by wire issues throttles with the 04's...that took a little while to get all the software gremlins sorted out.
Probably all them internet and wire things messin' everythin up agin.
Gonna wait for the 2013's, but then 2012 is comin round bend and I need a truck to make my getaway from the aliens blowin up them cities.
Cain't wait for Ford to pull it's head out of it's **** to fix them transmission gremlins.
Old Oct 11, 2010 | 11:49 PM
  #33
Muel's Avatar
Muel
Was it aliens? Or Solar Flare? Or AGW? or the Ice Age... I forget.
But on 11/11/11 at 11PM right?
Old Oct 12, 2010 | 02:12 AM
  #34
n578md's Avatar
n578md
Well you can thank Al Gore for that one. He invented the internet, it's a bunch of tubes.
Old Oct 12, 2010 | 06:15 PM
  #35
06sonicsport4x4's Avatar
06sonicsport4x4
How long does it take this "adaptive junk *** strategy" to correct terrible shifting. I have a 2010 and yes I am a 100% Ford man> my truck bangs the hell out of the 1-2 and then the 3-4 bangs and then slips. Its funny because my gf's old 91 with 250k miles did the same thing oh wait it had 250,000 miles on it. My truck has 2,600 and the trans is junk in my opinion. I have had 4 straight ford and yes they are a superior truck but these transmissions shift like crap.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Old Oct 12, 2010 | 07:40 PM
  #36
Greg B's Avatar
Greg B
That's why some of us will wait to buy until the problems are all sorted out. I don't think it's a problem with the transmission, but a problem with the way all the electronics interface. The geeks will figure it out eventually. But if it were me I'd be screaming at them all the way to Mullally if I had to to get it right. And if I were an executive at Ford I'd have some ***** working 24/7 to get it solved or they'd be unemployed.
Old Nov 4, 2010 | 08:09 AM
  #37
deltaboost's Avatar
deltaboost
My 2010 is doing a lot of the same things, but I attribute most of it to the controls. The trans seems strong, I've already done some heavy towing and saw none of the previously-stated issues under heavy load. It's the unloaded driving that I have trouble with. Just seems like it's always looking for a gear. I think a shift-kit would actually help a lot. If those shifts happened a little faster/harder, it wouldn't have nearly as much lag after hitting the throttle. At some point Ford will come out with a re-flash, just like GM did for my 06 Silverado. No big deal, that's what warrantees are for.
motopsyko32
Sep 20, 2011 10:26 PM
Voodoo ChildVood
Feb 2, 2011 08:36 AM
BLK94F150
Oct 17, 2009 11:54 AM
jonrjen
Modular V10 (6.8l)
13
Mar 2, 2007 06:46 PM
pappy_rh
Oct 23, 2003 06:34 PM
