Blower Motor Speed Control
Old Jan 31, 2011 | 02:12 PM
Voodoo ChildVood's Avatar
Voodoo ChildVood
Hello,
Does anyone know how the blower motor speed control works on a 1971 Ford F100. I have one speed and thats high and off. Any information would be greatly appreiciated!!! Thanks!!!
Old Jan 31, 2011 | 06:46 PM
Wilber15's Avatar
Wilber15
Needs a blower motor resistor......
Old Feb 1, 2011 | 02:01 AM
Voodoo ChildVood
Can you please tell me where the resistor is located? I have looked and the motor seems to be rigged up and spliced, so the resistor is probably missing. Thanks!!!
Old Feb 1, 2011 | 05:42 AM
n5926g's Avatar
n5926g
You will likely get a specific answer in the proper year model of the forum....with that being said,TYPICALLY the blower motor resistor block is mounted in the air ductwork somewhere close to the motor itself.
This resistor block screws in with i think 2 screws,and has a plug with relatively heavy gage wire,If memory serves a total of four.
Unplug the connector,and remove the 2 screws.You should see about 3 large coils of wire connected at one end to one of the treminals,and the other ends connected to different pins on the connector plate.
Old Feb 2, 2011 | 08:36 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to 1967--1972 forum
AikenRooster
May 25, 2018 08:24 PM
john188971
2009 - 2014 F150
27
Sep 14, 2017 08:40 PM
carbonel28
2009 - 2014 F150
Jun 18, 2016 05:51 PM
mrmomo
2009 - 2014 F150
Nov 8, 2015 11:18 AM
drpratt
Apr 14, 2009 09:50 AM
