faint oil smell in cab & sluggish morning power
Old 05-09-2010, 10:36 AM
y0manda's Avatar
y0manda
y0manda is offline
Trucks warranty expired last month on the 9th, has small oil leaks and thought I can bring it in befor I hit the 100k mark on odometer, well when I called my warranty had expired. I was too busy with work to bring truck in for warranty repairs and now I have to fix this and future engine problems myself. When I start truck in morning I have sluggish power till truck warms up. I think it may be injectors because I have had this problem with my truck before and brought it to for for repair. I also smell a bit of burnt oil in cab and when I park truck when I walk in front of it, I think this also has to do with injectors bit not sure. Truck doesn't leave any oil drops on driveway but has a oil drop always hanging under engine. What can I do as frar as diagnostic goes? And if it is the injector does it let me know which one to fix? Are there write ups on replacing injectors I have no clue on where to start. Thanks for everyone who helps me out.
Old 05-09-2010, 10:47 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
First things first. It helps us greatly to know the year model of the truck. Second--the "hanging chad" as I call that drip on the bell housing may or may not ever hit the ground and IMHO is nothing to worry about if it's not even leaving a drop in your driveway. Get your truck code scanned or buy a GOOD code scanner, especially if you are going to do the work yourself. It's simply invaluable on these trucks. There is a LOT of information in the 6.0 tech folder at the beginning of this forum for almost every problem encountered on these motors, including injector replacement. Burnt oil smell indicates that you have oil getting on a hot pipe (most likely a manifold) but no drops on the ground also indicate that it's a very small amount. If you've had injectors replaced before it could be an incorrectly tightened valve cover gasket (reusable many times) dripping on the manifold. 12mm wrench for those.
Old 05-09-2010, 11:26 AM
y0manda's Avatar
y0manda
y0manda is offline
Thanks for the quick respnce, I was typing this with 5% battery left on my phone.
I have a 6.0 '05 f250 wit no mods. Truck has 92k miles on it.
I will have to get it scanned is this something I can check with the kragen OBD2 readers? the check engine light is not on.
Old 05-09-2010, 11:27 AM
y0manda's Avatar
y0manda
y0manda is offline
Old 05-09-2010, 11:47 AM
lupe803's Avatar
lupe803
lupe803 is offline
When my truck had that faint burnt oil smell, I could smell it thru the air vents when I turned on the AC. It ended up being the egr oil cooler. I took it in right away and they replaced everything that was needed under warranty. Mine did it around 30k miles. Good luck...
Old 05-09-2010, 11:58 AM
y0manda's Avatar
y0manda
y0manda is offline
I had my egr cooler replaced when coolant blew out towing my 14k lb trailer up the cajon pass in victorville, ca. That happend last year about 7k miles ago
Old 05-09-2010, 12:04 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Was your oil cooler replaced as well?
Old 05-09-2010, 12:33 PM
y0manda's Avatar
y0manda
y0manda is offline
I don't think they replaced my oil cooler.
Old 05-09-2010, 12:53 PM
npccpartsman
deleted by blind uneducated user that can't read.
Old 05-09-2010, 12:57 PM
SteveBricks
If that's the case I think what you need to do now is monitor your oil and coolant temperatures to see if there is over 15 degrees difference in the two (oil being the higher). If so your oil cooler's flow is restricted which will likely lead to another EGR cooler failure.
Januch09
6.7L Power Stroke Diesel
04-29-2016 04:56 PM
otho1972
1999 to 2016 Super Duty
13
10-27-2015 10:09 PM
Chief-e9
05-21-2011 11:22 AM
TexasA&M
01-14-2011 05:43 PM
17 Fords
04-03-2010 10:14 PM
Quick Reply: faint oil smell in cab & sluggish morning power
