I have a 2011 F350 6.7 and have had it in shop three times because every time i tow a trailer up a grade my coolant temp rises. It has been tested for everything and last time they changed thermostat and air charge sensor. It seems like the problem started after the last update. Every problem the 2011 has had my truck has been fixed for oil pan, injector hold down, transmission and flywheel! Now this issue and my warranty expires the end of November with under 50k miles
lower radiator blocked by grass/leaves.. outside
lower radiator blocked on the inside by crud..... power flush.
bad/sticking thermostat.
bad/slipping clutch fan.
water pump impeller degraded ..
I have a 2011 F350 6.7 and have had it in shop three times because every time i tow a trailer up a grade my coolant temp rises...
Welcome to the forum, otho1972. I want to get this into the hands of your regional customer service manager (CSM); they'll work with your dealer to ensure your truck keeps its cool. Since you're new, you may not have PM access yet. If that's the case, send an email to custserv@ford.com with your details; I'll need your full name, best daytime phone number, VIN, current mileage and servicing dealership. Please put my name ("Crystal") in the subject line and post here once you've sent it. That's how I'll know to go looking for your email.
My 2013 F250 PSD developed an almost imperceptible leak on the drivers side of the radiator. Truck would get hot under load, otherwise no real sign, except a sweet smell from the HVAC. Spent $1600 replacing the radiator with an OEM radiator. I learned about the Mishimoto unit afterwards.
